Go to Post There were no heroes on the team, just everyone doing their part. - nuggetsyl [more]
Unread 14-01-2008, 17:23
govvijay govvijay is offline
FRC #0540
govvijay is an unknown quantity at this point
Wiring the IR sensor board
I am a rookie programmer on Team 540 and I was just wondering how to wire the IR board. I know that Pins 1-4 are used for either positive or negative power supply voltage inputs. Pins 5-8 are used for the output signals associated with the motorcoach remote buttons. 9 and 10 aren't used.
With the IR board there are the rainbow colored wire. How does each wire correspond to each pin? I see that there are 10 wires, but which wire matches with which pin?
Also, what do I connect the wires to? Do they connect directly on the Digital Controller?
Thanks for your help.
Unread 14-01-2008, 18:34
Re: Wiring the IR sensor board
Look at the connector mounted on the IR board and you'll see the numbers "1" and "2" printed on the board close to the edge. Those are pins 1 & 2.
Unread 14-01-2008, 19:53
nick1230's Avatar
nick1230 nick1230 is offline
FRC #0888
nick1230 is an unknown quantity at this point
use either 1 or 2 and 3 or 4 for power supply. the other ones (look at the documentation because i don't have it with me right now) are the outputs. the outputs can get hooked up to the digital in side of the rc, each of them a signal wire. You need to ground all of them though. out setup is in an L shape, with the base of the L the ground and one signal and the upright part 3 more signal wires. we just just pwm cables for this. it works well enough for testing purposes
"Confucius say: He who play in root, eventually kill tree."
Unread 14-01-2008, 20:03
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Can someone show me a pic of how we connect the wires?
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 14-01-2008, 23:24
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Sure, here you go. This is the thread:
http://www.chiefdelphi.com/forums/sh...threadid=61368
This is the image:
http://johnmchilton.com/IRBoard.jpg
What place are we at? ... TODAI!
Unread 15-01-2008, 14:39
MiniNerd24's Avatar
Ahhhhh...Thank you now I get it.(It just so happens I've one of those boards in my junk drawer at home )
The system is down.
Unread 15-01-2008, 18:13
JohnC's Avatar
There were also 2 in the kit
Unread 18-01-2008, 00:43
AdmiralAllen's Avatar
AdmiralAllen AdmiralAllen is offline
Master of Computers and Robots
AKA: Allen Worcester
FRC #1662 (Raptor Force Engineering)
AdmiralAllen will become famous soon enough
would it be possible to get a picture of the IR sensor wired to the onboard Computer?
Unread 18-01-2008, 01:03
JohnC's Avatar
Those cut-up pwm cables just plug into the digital inputs. I used inputs 7-10 to save 1-6 for interrupts. It's also possible to use fewer cables to do it, and plug the pwm cable in along the signal line of the inputs you want to use, but I did it using 4 separate cables.
If that doesn't make sense, email me so I see it when I get into the lab tomorrow and I'll put up a pic of that too.
Unread 05-02-2008, 19:41
naruto137 naruto137 is offline
FRC #1656
naruto137 is infamous around these partsnaruto137 is infamous around these parts
Wait, so you have to ground all the black wires on the PWMs to the battery you are using?
Need tips on wiring the IR board Bryan Herbst Control System 4 12-01-2008 18:34
Wiring for the allegro gear sensor mechanicalbrain Electrical 4 19-02-2006 17:03
The Hall Effect sensor wiring? LaughingJack Electrical 11 21-02-2005 13:35
wiring the optical sensor bob1million Electrical 2 24-01-2004 11:00
Optical sensor wiring with the EDU Robot Geoffrey4283 Electrical 3 15-01-2003 21:03
