Go to Post Ya know something I heard, UFH always look beter in PINK! :) - Kyle Love [more]
Unread 18-01-2008, 03:14
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Brake / Coast: any difference this year?
How did you connect the brake/coast header to a digital output port? Did you just take a standard PWM cable, plug it in, and then send it a 1 or 0 for brake or coast?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 18-01-2008, 17:30
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Just connect a digital output to the center pin on the brake/coast header, i think if i remember corrently that 0 is break and 1 is coast, also if no signal is givin (as in the cable fell out) it defaults to brake
Unread 18-01-2008, 17:57
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Exclamation Re: Brake / Coast: any difference this year?
you could always try to set it up so you can switch between the two modes.
FEAR THE HAWK!!!
Unread 22-01-2008, 22:41
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
With our drive base going 12 feet per second on mecanum wheels, we prefer BRAKE and leave it as such. Keep in mind the traffic we will most likely encounter and the importance of manuverability to get around said traffic. We can't have our robot coasting and sliding into everything at 12 fps.
Unread 22-01-2008, 23:07
The Lucas's Avatar
CaMOElot, it is a silly place
My team makes its own PWM cables, so I just take a 24 gauge white wire and crimp a female terminal onto each end. One end I insert into a housing and plug into the the digital output. I shriktube the other end (to prevent shorts) and plug into the middle pin of the brake/coast header. I make sure to tie wrap it down near the speed controller so the terminal doesnt get knocked off the header.
If you dont make your own cables, you may have to cut the male ends off of 2 PWM cables and solder them together. Then take the white pin out of one housing, shrinktube it and connect it to the middle pin of the brake/coast header. Unfortunately, each of these cables costs you about $10 and is plenty of work to make.
Robot Inspector
Brake/Coast setting for speed controller cabbagekid2 Control System 0 16-02-2005 16:54
Brake/Coast setting for speed controller cabbagekid2 Electrical 0 16-02-2005 16:54
Victor 884 Brake/Coast Issues sciguy125 Control System 23 23-01-2005 14:46
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
Brake/Coast Jumper archiver 2001 3 24-06-2002 01:04
