Re: FRC Novice Programmer
You may want to check out easyC or WPILIB as they both have drivers ready to go. This allows you to focus just on the problem at hand and not getting an encoder or ultra sonic sensor to work. Also, easyC has a online window that helps you map your ports on your robot.
| Delphi Programmer Needed | SpringBok | Programming | 1 | 03-12-2006 13:49 |
| Advanced Programmer Needed!!! | punarhero | Programming | 7 | 21-03-2004 15:29 |
| S.O.P. (Save Our Programmer) | MisterX | Programming | 2 | 11-02-2004 16:14 |
| Need a programmer | Mike Norton | Programming | 15 | 24-01-2003 22:45 |
| Novice Question | dmellich | Motors | 7 | 11-01-2003 09:58 |
