Go to Post I think everyone just needs to chill out and realize what the real goal of FIRST is. - Koko Ed [more]
Unread 18-01-2008, 06:12
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
FRC Novice Programmer
Hi, I'm very familiar with the C programming language, but not familiar as to how it is used for FRC. Can anyone recommend the first steps that I should take to learning the libraries written for FRC? I know that there are the Kevin repositories. Is this the best place to start or is there a manual that has a listing of the libraries? I'm used to started a program from scratch...like programming a pic or rabbit microcontroller, but I would like to work off the shoulders of giants so that I dont need to reinvent the wheel.
Mahalo Nui Loa
Windell
Unread 18-01-2008, 07:40
CarterM's Avatar
CarterM CarterM is offline
ComplicatedMind
None #0006 (S.C.O.E. Robotics)
CarterM has a spectacular aura aboutCarterM has a spectacular aura about
Send a message via AIM to CarterM Send a message via Yahoo to CarterM
Re: FRC Novice Programmer
This guide basically explains all of the things that someone would need to get started. Here
I also found that Team 1540 has a nice guide.Here
(It also has a link to the one above...)
Let's hope this helps.
Fondy Fire 2194 // 2007-08 // Founder
2011 UW-Madison // FSAE
2013 MSOE // S.C.O.E. Robotics (CARD Collegiate)
Unread 18-01-2008, 07:54
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
You may want to check out easyC or WPILIB as they both have drivers ready to go. This allows you to focus just on the problem at hand and not getting an encoder or ultra sonic sensor to work. Also, easyC has a online window that helps you map your ports on your robot.
Unread 18-01-2008, 16:05
FRC #2477
Thank you very much Carter and King...hey that sounds like a law firm like Caufield and Bryers (sp?)! Ohh by the way king...what do you mean by "map the ports"?
Thanks!
Unread 18-01-2008, 16:17
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
When your in the online window you can see real time sensors, motors, etc.. You can leave comments to remind you what pin out is connected to. So when you go to write your code all your comments show up in drop down menus. For example you put a motor in when you select the drop menu to choose what pin number you see your comments. I highly recommend use the online window it eliminates hardware issues in trouble shooting.
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Delphi Programmer Needed SpringBok Programming 1 03-12-2006 13:49
Advanced Programmer Needed!!! punarhero Programming 7 21-03-2004 15:29
S.O.P. (Save Our Programmer) MisterX Programming 2 11-02-2004 16:14
Need a programmer Mike Norton Programming 15 24-01-2003 22:45
Novice Question dmellich Motors 7 11-01-2003 09:58
