Go to Post We didn't need a championship to recognize the kids on our [little league] team and we sure didn't need one to inspire them. If you want to go to the championships then work harder, don't try and lessen the value of the championships by letting everyone in. - FarmerJohn [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 13-01-2008, 07:03
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Arm Design Projects-help
I wonder if anybody can send me who to designed arm so that the user can put the length, weight. As projects for my engineering computing class.
Such as what kind of motor the length of arms, more theoretical I need.
I lock in. http://www.chiefdelphi.com/media/papers/2036
Two Excel sheets design the reduction to an arm. But is locks for my very nice but without understanding.
Monitor team 1946
Unread 17-01-2008, 11:34
mtomczak mtomczak is offline
mtomczak is an unknown quantity at this point
Re: Arm Design Projects-help
Greetings!
I'm not quite sure I understand the question, but if you're looking for an arm simulation you may find this to be useful: http://fixermark.googlepages.com/ArmSimulator.zip
It's a simulator I crafted recently that uses Panda3D (which you can get at http://www.panda3d.org) to render a simple one-joint arm with a PID controller. You can modify the length and mass of the arm. This simulator was designed to teach programming concepts, so it isn't hugely accurate from a mechanical engineering standpoint. But if you're looking for a place to start, this might be useful.
Best of luck!
-Mark
Unread 18-01-2008, 08:56
yara92's Avatar
AKA: Mohamed
Originally Posted by mtomczak View Post
Greetings!
Best of luck!
-Mark
Thaks I will try to see what is that
Unread 18-01-2008, 08:57
yara92's Avatar
AKA: Mohamed
Monitor team 1946
Thanks that what I looking for
Rage Arm Design TriggsJr General Forum 0 03-03-2005 10:40
arm design Zippiot Technical Discussion 32 27-01-2005 02:56
pic: arm design Stephen P Extra Discussion 17 17-01-2005 13:53
Telescopic Arm and grabber design help M. Hicken Technical Discussion 13 17-01-2005 12:56
Arm design - rotation mechanism? n0cturnalxb Technical Discussion 6 16-01-2005 18:28
