Go to Post We're 3 pounds over. Drill until the hole saw is too hot to touch, then go find something else to cut off while you wait for it to cool down. - Richard Wallace [more]
Unread 18-01-2008, 10:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Robot Weight
I really wouldn't worry about having the compete bottom of it weighing 85 lbs, as long as I knew I could make the rest of the robot weigh less than 35 pounds.
Weight down low is better than weight up high....think about what it takes to make the robot fall over.
What is the plan for the "stuff" that will handle the ball (if any)?
Unread 18-01-2008, 10:07
ScottieDo555's Avatar
ScottieDo555 ScottieDo555 is offline
Best of the best
AKA: Scott Donaldson
FRC #2219 (MegaHurts)
ScottieDo555 can only hope to improve
Send a message via AIM to ScottieDo555 Send a message via MSN to ScottieDo555
Re: Robot Weight
Originally Posted by Jimmy Nichols View Post
LEXAN is great. Strong and light. You can pick it up at most metal supply stores or Lowes and Hone Depot.
You might want to think about modifying your frame to make it lighter.
yea were going to cut some peices off, maybe drill some holes in the pnumatic cylinders.. LOLs. na were barly going to be the weight we want. were going for speed.
Team MegaHurts 2219
BEST PAINTBALL FORUM - www.mcarterbrown.com - BEST PAINTBALL FORUM
Unread 18-01-2008, 11:43
imdunne8 imdunne8 is offline
FRC #1736
imdunne8 has a spectacular aura aboutimdunne8 has a spectacular aura aboutimdunne8 has a spectacular aura about
Re: Robot Weight
This post of mine may help a few of you out with early weight estimates. It is a spreadsheet I made to calculate the weight of motors, transmissions, and electronics. We actually found that our robot will weigh significantly less than expected, probably under 100 pounds. That is far better than last year when we weighed in at 110.0!
Unread 18-01-2008, 12:04
tanmaker
Posts: n/a
Re: Robot Weight
we would like our robot to weigh about 60 lbs, but with some early calculations, we could end up weighing 65 lbs. Its all about speed for us so that weight should give us our max acceleration and speed.
Unread 18-01-2008, 12:10
legotech25's Avatar
legotech25 legotech25 is offline
Sarah
AKA: Sarah
FRC #1714 (TMCRC)
legotech25 will become famous soon enoughlegotech25 will become famous soon enough
Send a message via AIM to legotech25 Send a message via Yahoo to legotech25
Re: Robot Weight
Just be a little careful about how you structure your lexan/polycarbonate. 1/8" polycarbonate can do wonders... we build our entire robot out of polycarbonate every year.
Yes, polycarbonate is strong and light, but it can be flimsy in certain applications.
It makes an amazing electronics board, but using it in a drive train will take a little bit of planning. The easiest way to strengthen it is to bend the edges of your piece... It will still be bendable along the diagonals (if it's a square), but it will take a lot of flexability out of the center of the piece, which is what you need in a drive train.
If anyone needs any help in using polycarbonate, feel free to message me.
Good luck!
edit: After taking a second look, I see no one mentioned using polycarbonate in a drive train... oops... but I'll leave the information here anyway. Polycarbonate will be great for an electronics board.
Team Captain - More Robotics 1714
2009 Milwaukee - Chairman's Award
2008 Milwaukee - Chariman's Award
2007 Cleveland - Kliener Perkens Buyers Caufield Entrepenureship, Engineering Insparation
2007 Milwaukee - Kliener Perkens Buyers Caufield Entrepeneurship, Website, Motorola Quality Underwriters Laboratory Safety
2006 Atlanta - Rookie Inspiration
2006 Cleveland - Rookie All-Star, Safety Runner-up
2006 Milwaukee - Rookie All-Star, Safety Runner-up
pi = 3.141592653589793238462643383279502884197169399715 10 ^_^
Unread 18-01-2008, 12:23
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Robot Weight
Is that 85 lbs. with or without the battery?
Seems a little high however you do have pneumatics installed, which takes up quite a bit of weight.
Unread 22-01-2008, 14:04
Best of the best
Re: Robot Weight
thats with out the battery.
Team MegaHurts 2219
Unread 22-01-2008, 14:40
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Robot Weight
These are generous with roughly 10% overestimation each:
Drive Train - 40 (precise)
Manipulator - 35
Pneumatics - 23
Electronics - 7
Powder Coating - 5
We're looking at just over 110lbs.
GitHub
Unread 23-01-2008, 22:45
RTTComanche17's Avatar
RTTComanche17 RTTComanche17 is offline
12ga Browning
FRC #1662 (Raptor Force Engineering)
RTTComanche17 is on a distinguished road
Re: Robot Weight
we weighed our base and we weigh 55 pounds as of right now. thats out frame, drivetrain, and electronics. we still need pneumatics and our manipulator.
What's Your Motivation?
Unread 24-01-2008, 18:21
Capt. Quirk Capt. Quirk is offline
AKA: Bill Mazzacane
FRC #1704 (Robotic Steelers)
Capt. Quirk will become famous soon enoughCapt. Quirk will become famous soon enough
Re: Robot Weight
Shooting for 119, If it's light we will add lead
Unread 27-01-2008, 12:50
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Robot Weight
Right now we are 30 pounds + under without electronics.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 27-01-2008, 13:10
Brian J. R.'s Avatar
Brian J. R. Brian J. R. is offline
Pit Chief
AKA: Brian Richards
FRC #1983 (Skunkworks)
Brian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to behold
Send a message via AIM to Brian J. R. Send a message via Yahoo to Brian J. R.
Re: Robot Weight
I really don't know about our other parts, but our frame alone weighs 9 pounds, 1/8 aluminum (I think, possibly 1/16) Our claw is hopefully going to be composite, if we can get it to them within the week.
This is about all I can give for information as of now, I just transfered over to programming (of which I know none)
Hopefully if I remember I will post some spy shots of our super light frame within the week....assuming I remember.
Unread 27-01-2008, 13:16
Hito Seika's Avatar
Hito Seika Hito Seika is offline
aka Garrett
FRC #1225 (Amperage Roboticcs)
Hito Seika is infamous around these partsHito Seika is infamous around these partsHito Seika is infamous around these partsHito Seika is infamous around these parts
Re: Robot Weight
Are teem's robot is some ware between 25 and 80 pounds ( chasy, electronics board, drive trane,…) We still have a bit to go but I think the heaviest part of are bot is finished.
Sorry about my spelling ….I’m a horrible speller
Unread 29-01-2008, 23:12
BlackBird11891's Avatar
BlackBird11891 BlackBird11891 is offline
We Rise Above Our Challenges
AKA: Chad Krivanec
FRC #1927 (Team Tempest)
BlackBird11891 is on a distinguished road
Re: Robot Weight
our robots weight is 75 lbs. total done and completed
Unread 29-01-2008, 23:15
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Robot Weight
Our CAD model tells us 115...
It still doesn't have electronics, pneumatic tubing, wire, or chain....
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
What scales to weight robot? chocolateluvrlr General Forum 41 08-04-2005 21:43
Robot Part Weight List Don Wright Technical Discussion 3 20-01-2005 12:55
Robot size and weight Covey41 Rules/Strategy 8 10-01-2005 10:32
Dynamic Robot Weight Calculator SilverStar Technical Discussion 0 21-01-2004 19:21
Robot weight dimroed Rules/Strategy 3 18-02-2002 21:31
