Go to Post The only thing happy about ship day is the promise of sleep coming soon... - StephLee [more]
Unread 18-01-2008, 10:11
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Post Pneumatics Part # restrictions
Given that we are limited the Bores and Strokes listed on the bimba form are we also limited to DP for 3/4 and 1.5 and DXP for 2" cylinders? Nose mount (D mount) cylinders are illegal?
Unread 18-01-2008, 10:14
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Pneumatics Part # restrictions
Technically not legal, but ask the Q&A: this is often an issue at inspection, and they may be willing to broaden the interpretation. The cylinders are functionally equivalent, as long as you don't take advantage of the different back end of the cylinder on the D models (they have no clevis, and the port is centred on the axis of the body).
Unread 18-01-2008, 10:17
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It might be unfair to those teams who use the specified cylinders, since they weigh more than the same size D model, to use that example.
Unread 18-01-2008, 11:50
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
You have to use the exact PN as indicated, including the mounting end.
All you can modify is to remove the pin in the clevis if you want to bolt the cylinder in place, and you can choose how to mount the extending end (clevis, but and bolt, etc.).
We proposed to use the front mount versions for transmission shifters a few years ago, because they are shorter, but we told we could not, via an official Q+A.
While the function of the cylinders is the same, the rule is there to assure that all teams have the same aprts and the same issues with mounting them,
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 18-01-2008, 14:16
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
This question comes up every year and the answer has always been the same as Chris mentions above. Use only what is listed on the cylinder order sheet as anything else will probably not pass inspection.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 19-01-2008, 20:05
nighthawk0501's Avatar
nighthawk0501 nighthawk0501 is offline
FRC #2022 (IDK)
nighthawk0501 is an unknown quantity at this point
Send a message via AIM to nighthawk0501
does anyone know if we have to use a clevis? or can we have on built in to our robot?
Unread 19-01-2008, 22:59
Rookie Year: 1942
You do not have to use the clevis, but you cannot alter the actual cylinder as it comes out of the package, except to remove the pin.
Chris Fultz
Unread 20-01-2008, 01:08
Kat Kononov's Avatar
Kat Kononov Kat Kononov is offline
AKA: artqny
FRC #2022 (Team IDK)
Kat Kononov is an unknown quantity at this point
Send a message via AIM to Kat Kononov
<R92> Pneumatic components supplied in the Kit Of Parts (compressor, regulators, pressure switches, cylinders, valves, fittings, tubing, etc.) can not be modified except as follows:
• The tubing may be cut.
• The wiring for the valves and pressure switch may be modified as necessary to interface with the control system.
• Mounting and connecting pneumatics components using the pre-existing threads, mounting brackets, etc., is not considered a modification of the components. Removing the pin from the rear of an air cylinder is allowed as long as the cylinder itself is not modified.
Do not, for example, file, machine, or abrasively remove any part of an air cylinder. Consider pneumatic components sacred. They must remain in “out of the shipping box” condition.
I think this is the rule associated with your question. It doesn't say that you have to use the clevis. You can mount the cylinders using the threads that are on them, or example.
Unread 28-01-2008, 23:09
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC &amp;amp; FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
We have a 24" stroke cylinder in our supply which is the 1.5 inch bore. It was on the free cylinder form a few years back. The only 24" stroke cylinder on the free cylinder form this year is the 2 inch bore. So if cylinders from previous years are legal is this cylinder legal? I am leaning towards no citing the identical to free parts quote.
<R89>
In addition to the pneumatic cylinders provided in the Kit Of Parts and the “free” pneumatic
cylinders available for order through the Free Pneumatic Components Order Form,
additional air cylinders or rotary actuators may be used. All cylinders, regardless of source,
must be identical to those listed on the Free Pneumatic Components Order Form (e.g. same
part numbers). Any additional air cylinders must source from Bimba or Parker Hannifin, or
be recovered from prior year FIRST Kit Of Parts.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 28-01-2008, 23:26
By the rule you posted, it is not. Also see Q&A. It must be identical to the free ones from this year's order sheet.
Unread 28-01-2008, 23:36
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
What is the purpose of the last sentence of <R89>? Just to legalize the 1.5x8 Parker cylinder from KoPs past? Or does that one even count?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 28-01-2008, 23:39
MrForbes's Avatar
AKA: Jim
I think it is just to legalize that one cylinder...good thing too...we're using it in our design so far...
Unread 28-01-2008, 23:44
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Having read the Q&A tonight on pneumatic cylinder restrictions, The GDC response is kind of funny. There were 5 teams requesting variances to the allowed cylinders. The one answer the GDC recommended was exactly what is being said here by the CD community. If it's not on the approved 2008 list, it's not allowed.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 29-01-2008, 00:12
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
The wording of <R89> had me confused for a while. This answer clears things up for me.
http://forums.usfirst.org/showthread.php?t=8447
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 29-01-2008, 00:48
I'm a little surprised by that response, because without some creative interpretation (which we might call "lawyering"*), it's hard to reconcile with the rule, which states:
All cylinders, regardless of source, must be identical to those listed on the Free Pneumatic Components Order Form (e.g. same part numbers).
Parker cylinders do not have the same part numbers as Bimba cylinders, so what are we to conclude? Hypothetically, I suppose the "e.g." clause could be a non-binding clarifying example like the one previously provided for the 80-inch rule (as opposed to "i.e.", which would be an unambiguous pronouncement), and "identical" could be short for "functionally identical". Even if that might be the case, I'd have to say the most obvious interpretation of the rule is that every cylinder's part number must match one provided on the form—why else would you give the example of matching numbers? Either way, that's worth clarifying once and for all in an update (if a rule is to be changed), or an unambiguous Q&A response.
Also (if we accept the permissive interpretation given above), why does the response state that these Parker cylinders must be from an old kit? If functionally identical (as opposed to matching-numbers identical) Parker cylinders are permitted under the 2nd sentence of <R89>, then according to the 3rd sentence, if they come from Parker, it's not necessary that they be from an old kit. (It must be either from Parker, from Bimba, or from an old kit; no combination of those things is required.)
*Not this again!
Rules and restrictions seawolf814 Technical Discussion 3 16-01-2008 16:52
Wheel restrictions seawolf814 Technical Discussion 1 14-01-2008 18:40
Monty Madness Weight Restrictions Tobaby817 Off-Season Events 1 10-05-2006 16:48
Site Restrictions Darek905 Website Design/Showcase 7 20-04-2003 16:56
3 letter word restrictions??? Yucky!!! Elgin Clock CD Forum Support 4 15-12-2002 16:19
