Go to Post Everyone needs to start working with what they are given, and start appreciating FIRST, not complaining about what they think FIRST is doing wrong. - Marygrace [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 18-01-2008, 11:31
neha neha is offline
neha is an unknown quantity at this point
Atmega32 port c pins
my team has designed a programmer for atmega32. all ports can be programmed successfully however pins 2,3,4,5(starting with 0) of portc cannot be programmed. we wrote a flash led programmer however these mentioned pins do not show any variation. they are showing a constant high. pls help us at the earliest.. thanks
Unread 18-01-2008, 11:53
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Atmega32 port c pins
How are you programing the device? There are multiple methods. These methods are ISP, JTAG, DebugWire, Parallel, and High Voltage. Im suspicious of the fact that pins 2,3,4, and 5 form the basis of JTAG programing.
EDIT:
I think I figured it out. You have JTAG programing enabled. The datasheet says:
If the JTAG interface is enabled,
the pull-up resistors on pins PC5(TDI), PC3(TMS) and PC2(TCK) will be activated even if a reset
occurs.
Hence the reason why the pins don't change value. Try disabling it through the fuse settings.
using all port pins AMIRAM Programming 4 23-01-2006 00:52
pic: Pins Pins and more pins CD47-Bot Extra Discussion 26 04-09-2005 23:07
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
TTL pins Dave... Control System 3 07-02-2004 23:59
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
