Go to Post Nope, nope... no adults here. We're all kids. :) - Andy Baker [more]
Unread 18-01-2008, 11:58
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by Mike Mahar View Post
Kevin,
In your gyro initialization code in teleop.c, you have two static ints that you use as counters. (i, j) You increment both every time through the function. When you wish to print out the gyro you have the following:
if(i == 35 && j >= 300)
Since i has been incrementing all along, it will be equal to j. The next time i == 35 j will also be equal to 35. Putting i = 0 into the
if(j == 300)
body should fix that. You also need to put i = 0 into the body of the
if(==35 && i >= 300)
statement if you aren't using the encoder code.
Thanks, I'll have a look to see if I can clean it up a bit.
-Kevin
Kevin Watson
http://kevin.org
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
