Go to Post That's right 10 years and this is the first time ever that the school wanted anything to do with the FIRST team. - RoteAugen [more]
Unread 18-01-2008, 13:13
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: easyC pro code needed
http://www.chiefdelphi.com/forums/sh...hlight=mecanum
This is for 4 wheel mecanum.
Unread 18-01-2008, 16:36
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Originally Posted by Kingofl337 View Post
tamra-afr.net
Unread 19-01-2008, 08:38
yara92's Avatar
AKA: Mohamed
I downloaded your program and it didn't work well , it seems to be designed for xbox 360 joystick
can you send me a code for a regular joysticks for 2 ports
thanks
Unread 19-01-2008, 20:05
Kingofl337's Avatar
AKA: Adam
There was a small "bug" in the code the Spin joystick was the same port as the Y translation joystick. I've updated the code but you can just update the version you downloaded.
Download easyC PRO & 2007 Kickoff Code Kingofl337 Programming 1 24-01-2008 09:15
MS Vista/EasyC & EasyC Pro rswsmay Programming 1 25-04-2007 10:47
Kevin's PWM 13-16 Code in easyC PRO Kingofl337 Programming 0 02-02-2007 09:03
