Go to Post If FIRST is going to succeed in its goals, then we need to help it. - jcatt [more]
  #31   Spotlight this post!
Unread 18-01-2008, 09:58
David Hoff's Avatar
David Hoff David Hoff is offline
FRC #4050 (Biohazard)
David Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to all
Re: 80/20 ?!?!?!
I've been looking around and haven't been able to find this so I was wondering if anyone knows what the weight comparison is between 1" x 1" 80/20 and 1" x 1" aluminum square tubing with either 1/16" or 1/8" wall thicknesses.
Cyber Blue Team 234: Indianapolis, IN 2002-2006
Purdue FIRST Programs: West Lafayette, IN 2006 - 2010
Cyber Titans Team 3793: Frederick, MD 2012
Biohazard Team 4050: Chambersburg, PA 2014
  #32   Spotlight this post!
Unread 18-01-2008, 10:10
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Re: 80/20 ?!?!?!
The entire 8020 catalog is on line and they have weight, tesile strength, etc all in there for both 1010 and 1" tubing ... http://www.8020inc.net/
1010 = .5097 lbs/ft pg 4
1x1 square tubing, .125 thich = .516 lbs/ft pg 81
  #33   Spotlight this post!
Unread 18-01-2008, 10:14
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 80/20 ?!?!?!
We have never used it, not quite sure why but probably because we can buy aluminum angle, square tubing, round tubing, etc locally along with pop rivets and bolts and nuts.
Seems to me that the more universal a part is, the less likely it is to be "just right" for anything.
  #34   Spotlight this post!
Unread 18-01-2008, 10:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: 80/20 ?!?!?!
Originally Posted by ahecht View Post
I would hope that Bosch doesn't have bins and bins of 80/20, as they are a direct competitor. I assume it's Bosch-Rexroth aluminum framing.
Hahahahahahahaha!!! Oh man.. that just made my day... lol
Btw, 80/20 1" "square" 1010 series has a hole in the middle of it as you may have noticed.
This is the perfect size to tap a hole for a 1/4-20 screw into.
That's usually the job the freshmen on the team get when they want an intro to manufacturing.
It's a simple task, and a prerequisite on our team to know how to tap those before moving onto more difficult tasks.
  #35   Spotlight this post!
Unread 18-01-2008, 13:43
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: 80/20 ?!?!?!
Originally Posted by tseres View Post
excuse my ignorance, but what exactly is the 80/20 stuff?
Sometimes people call it '80% of what you want for 20% of the effort'.
It's a system of extruded aluminum and fasteners that allow for quick and easy modifications. Attaching pieces of it together requires, typically, no more then hand tools.
The down sides are typical to any sort of modular building kit; Cost and weight. It's not cheap, and the fasteners aren't either. Because of the shape of the extrusion required to make the fasteners easy to use it's heavy for it's size.
It's a pretty high price to pay for the ease it offers. But a lot of rookie teams make use of it because you can toss a frame together with nothing more then a hacksaw and a wrench. If you don't have much in the way of tooling, or experience with frame building, it can be a godsend. Otherwise more traditional extrusions and fasteners offer much more.
  #36   Spotlight this post!
Unread 18-01-2008, 19:55
ida_noeman's Avatar
ida_noeman ida_noeman is offline
AKA: phobbs
FRC #1719 (Umbrella Corp.)
ida_noeman is on a distinguished road
Re: 80/20 ?!?!?!
Where can you order 80/20 from?
"Weeks of coding can save you hours of planning"
"If the code was hard to write, I'm dam well going to make it hard to read!"
  #37   Spotlight this post!
Unread 18-01-2008, 20:11
run the trap!!!
Team Role: Human Player
Re: 80/20 ?!?!?!
Ues this link to find a disributor near you. Tell them what you need and they'll send you a quote. Then you can send in your quote and get the parts in a matter of days.
If you want to order online, there is an Ebay-store that carries it.
-Philip J. Fry
  #38   Spotlight this post!
Unread 18-01-2008, 22:46
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: 80/20 ?!?!?!
We're using 80/20 this year for a elevator and with the linear motion slides they sell the whole system was easy to build and rather simple and doesn't weigh too much
-Dustin Benedict
  #39   Spotlight this post!
Unread 19-01-2008, 22:34
Armando Gonzalez's Avatar
Armando Gonzalez Armando Gonzalez is offline
FRC #1872 (Yellow Fever)
Armando Gonzalez has a spectacular aura aboutArmando Gonzalez has a spectacular aura about
Send a message via MSN to Armando Gonzalez Send a message via Yahoo to Armando Gonzalez
Re: 80/20 ?!?!?!
We have substituted our Bible with an 80/20 catalog.
Armando Gonzalez
Team 1872 - Yellow Fever
San Juan, PR
Awards
Rookie Inspiration Award - 2006 UCF Regional
  #40   Spotlight this post!
Unread 19-01-2008, 23:02
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: 80/20 ?!?!?!
You can get some pretty good deals at http://stores.ebay.com/8020-Inc-Garage-Sale
Some of the stuff is auctioned (like 1010 extrusion), others items (like fastener hardware) is "Buy it Now".
You can save quite a bit of money through this e-bay seller. Don't forget to use the normal retail price when you do you cost accounting for the robot BOM.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
  #41   Spotlight this post!
Unread 20-01-2008, 11:48
team 2191's Avatar
team 2191 team 2191 is offline
Nottingham High School Robotics
FRC #2191
team 2191 is an unknown quantity at this point
Re: 80/20 ?!?!?!
what is 80/20?
  #42   Spotlight this post!
Unread 20-01-2008, 12:13
Re: 80/20 ?!?!?!
Originally Posted by team 2191 View Post
what is 80/20?
It's structural extruded aluminum with special fasteners (like "drop-in" nuts) that can simplify building the chassis and other portions of the robot.
Team 980 has used 80/20 1010 extrusion for the chassis for years. It may be more expensive that square extrusion, but the strength/weight ratio and ease of assembly more than justifies the extra cost. This year, I purchased the 1010 stock for our robots on e-bay at a substantially lower price than what you'd pay at distributors. See my post above for more info (post #40).
BTW, before posting in CD, you should at least read the thread in which you're asking questions. Please read posts #11 (photo of 80/20 extrusion attached) and #35.
