Go to Post I believe it is in the spirit of the game is to score more points than your opponent within the rules. That means offense AND defense. - Gary Dillard [more]
Unread 18-01-2008, 14:33
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: The Best Remote to Use?
I have to respectfully disagree with you on that, tanmaker.
Remotes do have different range capabilities, so picking the right remote could be important (although most remotes will handle this competition just fine).
Additionally, different remotes handle signals differently. Some send 1 pulse for each button press, while others will send a continuous stream of pulses as long as the button is held down. This aspect is perhaps more important than the strength of the remote (as i said, most will work fine for this competition), as it involves programming your robot differently based on the remote. If you know you'll only get 1 pulse per button press (regardless of how long you hold it down), then you can treat each pulse as a separate press. If you have that same code but a remote that sends a continuous signal of pulses as long as the button is held down, odds are you'll get multiple signals to the robot for each button press and possible unintended results.
Unread 18-01-2008, 16:22
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
Can anyone recommend a certain brand or model that has had exceptional results?
BEST USE of the IR Remote!!! waialua359 Control System 34 13-01-2008 10:55
What kind of battery does your IR remote use? Elgin Clock Electrical 0 09-01-2008 12:14
What are the best wheels to use on carpet? The GarbageMan Kit & Additional Hardware 10 09-04-2007 20:29
Remote Remote Kickoff for Southern California ChrisH Southern California Regional Robotics Forum 0 05-01-2004 12:36
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
