Go to Post Because, y'know, FIRST can't make it easy for us. - WinterPoet [more]
Unread 18-01-2008, 14:34
Chara09 Chara09 is offline
AKA: Adam
FRC #2234 (EA Robotics)
Team Role: Electrical
Chara09 is an unknown quantity at this point
Send a message via AIM to Chara09
IEC Limit Switch from KoP
I was wondering if anyone could explain how to wire it for me or, even better, get me a picture of a wired one. Thanks.
Unread 18-01-2008, 14:52
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: IEC Limit Switch from KoP
You should put the common pin from the switch to ground, and either the NC or NO contact (depending on your preference) to the signal pin of a digital I/O port.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 18-01-2008, 15:00
Limit switches are typically connected between the ground and signal pins of a digital input on the Robot Controller. On a standard PWM cable, that's the black and white wires; the red wire is not used. Use the two contacts on the limit switch that are an open circuit when the switch is not active, and a short circuit when the switch is active. The switch I have handy to look at labels those contacts COM (for "common") and NO (for "normally open"). The software will see a logic 1 on the input change to a logic 0 as the switch is activated.
You can also use the COM and NC ("normally closed") contacts instead. That will result in a logic 0 when inactive and a logic 1 when active. It will also give a logic 1 if the wires to the switch come loose, which might be either a good or a bad thing depending on what the software does with it.
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
Limit Switch Basics JWSnedden Programming 6 30-11-2006 19:48
Limit switch in easy c? chadbarbe Programming 6 02-02-2006 09:51
