Go to Post Simply. Minimize. Reduce. It's a good engineering rule, and an even better management one. - Tom Line [more]
Unread 18-01-2008, 15:38
team 2191's Avatar
team 2191 team 2191 is offline
Nottingham High School Robotics
FRC #2191
team 2191 is an unknown quantity at this point
Exclamation Caster questions?
Will a bot with four casters and 2 drive wheels placed in the center be able to function in the overdrive comptetion? Please answer back a.s.a.p.
Team 2191
Unread 18-01-2008, 15:40
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
Re: Caster questions?
it should i dont see y not be i would think bout replaceing the caster with omni wheels
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 18-01-2008, 15:42
GaryVoshol's Avatar
Cogito ergo arbitro
Legal? Yes.
You'll have to research for yourself whether or not it would be effective.
(since 2004)
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Yes. It will certainly be able to function, the thing to keep in mind though is the length of your motors. They are "almost" designed to go in the center. It will probably have great turning and if done right is a great idea. Good luck on figuring this out, and I hope it works well for you.
Unread 18-01-2008, 15:44
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Team 2191
I would caution against it.
If a caster gets raised on a bump in the carpet or a part off of another robot you can unload both of your center wheels and will be stuck.
Happened to us four years ago.
Elgin Clock's Avatar
FRC #0237 (Black Magic)
It's a configuration that worked great for us in the past.
http://www.chiefdelphi.com/media/photos/13930
The center wheels were pneumatic (air filled) while we had 4 casters on the 4 corners of the robot.
Be careful as to where you mount your casters in relation to your center wheels.
You more than likely want all 6 wheels touching the carpet on the same plane, so mounting the casters lower (if they are smaller than your drive wheels) is necessary.
The bad thing with this design is that your robot can and will be able to spin very easily.
Your turning point on your robot will now be directly in the center of the chassis (re: right in the middle of your center drive wheels).
Cool for "crazy death spins" but not so cool if you lose your bearing as to which is the front, and have to turn a lot.
I personally think that design would be sucessful as far as a straight lap robot.. (ie: one meant just to drive around and do laps) but not for any robot that wants to carry or hurdle a ball this year.
Unread 18-01-2008, 16:05
That's both a good thing and a bad thing, depending on whether or not you want to spin. You should carefully consider how you'll be controlling the turns in the Overdrive game. Think of it as a challenge for your programmer.
Unread 19-01-2008, 15:16
DonRotolo's Avatar
Back to humble
FRC #0832
Hint: The gyro can be used to measure the number of degrees that the robot turns.
3 Questions!!! (2/10/04) Andy Grady General Forum 9 10-02-2004 21:42
Dimension Wanted - BOM Caster: floor to top plate surface height kmcclary Kit & Additional Hardware 2 28-01-2004 12:02
Caster Mechanism mzitz2k Technical Discussion 11 01-01-2004 17:01
Building a better caster. Madison Technical Discussion 14 16-01-2003 22:53
Caster Modification archiver 2001 1 23-06-2002 22:58
