Go to Post STEM blushes, and asks if Art would like to go out for a date. - Cothron Theiss [more]
Unread 18-01-2008, 16:17
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
Re: FRC Novice Programmer
When your in the online window you can see real time sensors, motors, etc.. You can leave comments to remind you what pin out is connected to. So when you go to write your code all your comments show up in drop down menus. For example you put a motor in when you select the drop menu to choose what pin number you see your comments. I highly recommend use the online window it eliminates hardware issues in trouble shooting.
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Delphi Programmer Needed SpringBok Programming 1 03-12-2006 13:49
Advanced Programmer Needed!!! punarhero Programming 7 21-03-2004 15:29
S.O.P. (Save Our Programmer) MisterX Programming 2 11-02-2004 16:14
Need a programmer Mike Norton Programming 15 24-01-2003 22:45
Novice Question dmellich Motors 7 11-01-2003 09:58
