Go to Post Bottom line - keep your passion for FIRST and don't let others spoil your fun! - Sean Schuff [more]
Unread 18-01-2008, 16:29
Xenozero Xenozero is offline
Xenozero
AKA: The inovator
FRC #1230 (Lehman Lionics)
Xenozero will become famous soon enough
Send a message via AIM to Xenozero
Need A little Help
My team and I are currently trying to post a question on the official FIRST Q&A and cant seem to figure out how to post anything. We signed up for the forum and went to the forum space labeled "Submit your 2008FRC question here" and all of the threads are locked, and we are unable to post anything, is there a certain procedure needed to post on their forum?
Unread 18-01-2008, 17:17
jalburty jalburty is offline
Joe Alburty
AKA: Joe Alburty
FRC #1763 (Paseo Pirates)
jalburty will become famous soon enoughjalburty will become famous soon enough
Send a message via ICQ to jalburty
Re: Need A little Help
I don't know how help with posting a questionon FIRST Q&A, but in the mean time maybe you could post your question here on CD. Just a suggestion.
Unread 18-01-2008, 17:42
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
make sure you are logged in before trying to post? i think only the Primary contact and post a question.
Unread 18-01-2008, 17:59
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Your primary team contact (the person that registered your team on TIMS) should have the login information for your team's access to the FIRST Q&A system.
When a question is submitted you will not see it show up immediately in the forums. All the FIRST Q&A forums are moderated, and submitted questions have to be approved before they are visible. From that point, most of them are immediately moved over to a separate area for review by the FIRST, the GDC, FIRST Operations, or whomever is the appropriate group to answer the question.
The question is then reviewed and an answer is developed, debated, argued, examined, bent, folded, spindled, mutilated, flattened, ironed out, and finally agreed upon. Once that process concludes, then your original question and the answer will be posted in the "2008 Q&A Responses" section of the forums.
Depending on the question and the complexity of the answer, it may be anywhere from a few minutes to a few days before the answer is posted. The folks that answer the questions are very aware that time is critical and everyone really wants to get the responses out as quickly as possible. But more importantly, they want to make sure that the responses are accurate. In some cases, the research behind a seemingly innocuous answer can take a considerable amount of time and coordination effort between all the folks involved. So if your answer does not show up immediately, please bear with the process and be assured that it is being worked "behind the scenes," and will be answered as rapidly as possible.
-dave
Need a little help with how to break out of the box amateurrobotguy Programming 6 16-01-2006 12:56
Need a little help on somthing 157#1Driver General Forum 4 03-12-2002 22:07
I need a little help... Sachiel7 Technical Discussion 5 25-09-2002 21:49
We need a little help Justin Howard General Forum 3 23-02-2002 11:41
