Go to Post Someone Photoshopping Heidi...............now there's a switch! - Jay H 237 [more]
  #241   Spotlight this post!
Unread 17-01-2008, 20:26
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by Kevin Watson View Post
I had a look at your code and it looks like the problem is your limit() function, which is returning a 16-bit integer when it should return an unsigned 8-bit byte.
This is probably one of the big things to watch for, even for experienced programmers. The MPLAB/PIC18 platform (and embedded platforms in general) are a lot less tolerant of type mismatches than your usual programming.
  #242   Spotlight this post!
Unread 17-01-2008, 21:46
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Thumbs up Re: New C18 3.0+ Compatible FRC Code
You're waiting because I'm deep in procrastination mode and haven't finished the first cut of the documentation yet <grin>.
-Kevin
I think someone needs to pull a high priority interrupt and put everything else you are doing on hold! This should be your top priority, cuz I said so.
"Procrastination mode" I wonder if FIRST will use that to replace Hybrid mode next year?
  #243   Spotlight this post!
Unread 17-01-2008, 22:28
in between teams
AKA: Luke Van Oort
Well, in the past, the difference wouldn't be very noticeable...
Team 1219: 2009 - Mentor
  #244   Spotlight this post!
Unread 17-01-2008, 23:46
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by Jon236 View Post
BTW, would you think that using 4 interrupts,INT's 3-6, at 128 ints/sec (every ~8ms) would be overstressing the processor?
I depends on what else is executing on the processor, but in general you shouldn't have a problem.
-Kevin
Kevin Watson
http://kevin.org
  #245   Spotlight this post!
Unread 18-01-2008, 01:55
FRC #2429
Okay, here is a snapshot of the current build that includes support for encoders and gyro:
http://kevin.org/frc/ifi_frc_beta_4.zip
*Please* help me out and have a look at the code and documentation (start with readme.txt) and provide feedback before I go public with the code on my website, which I'd like to do on Friday or early Saturday. If you can, follow the directions in readme.txt to build the code and test with your encoder(s) and/or gyro and report any problems here. Thanks.
-Kevin
Edit: Code has been released and is available here: http://kevin.org/frc.
-Kevin
Kevin Watson
http://kevin.org
  #246   Spotlight this post!
Unread 18-01-2008, 11:05
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Kevin,
In your gyro initialization code in teleop.c, you have two static ints that you use as counters. (i, j) You increment both every time through the function. When you wish to print out the gyro you have the following:
if(i == 35 && j >= 300)
Since i has been incrementing all along, it will be equal to j. The next time i == 35 j will also be equal to 35. Putting i = 0 into the
if(j == 300)
body should fix that. You also need to put i = 0 into the body of the
if(==35 && i >= 300)
statement if you aren't using the encoder code.
  #247   Spotlight this post!
Unread 18-01-2008, 11:58
FRC #2429
Originally Posted by Mike Mahar View Post
Kevin,
if(j == 300)
Thanks, I'll have a look to see if I can clean it up a bit.
-Kevin
Kevin Watson
http://kevin.org
  #248   Spotlight this post!
Unread 18-01-2008, 16:07
billbo911's Avatar
In the README.TXT, in the section to enable the ISR's in ifi_frc.h, (bullet # 3)the description is misleading, or the file is incorrect.
3) Enable the interrupt service routines associated with each encoder
channel at the top of ifi_frc.h.
When looking at the file, the lines do not indicate that you are enabling an ISR.
// #define ENABLE_INT_1			// enable if using encoder channel 1
// #define ENABLE_INT_2			// enable if using encoder channel 2
// #define ENABLE_INT_3			// enable if using encoder channel 3...
Documentation error, code error, reader misunderstanding error???
  #249   Spotlight this post!
Unread 18-01-2008, 16:34
FRC #2429
Given the comments above and alongside those #defines, I don't see how a user wouldn't be able to figure it out:
// Remove the comment slashes from one or more of the following lines to
// enable the respective external interrupt(s) and/or timer(s). By doing
// so, you only enable the code within ifi_frc to become part of your
// software build.
// #define ENABLE_INT_4 // enable if using encoder channel 4
// #define ENABLE_INT_5 // enable if using encoder channel 5
// #define ENABLE_INT_6 // enable if using encoder channel 6
I'd be happy to change it, but I don't fully understand the problem...
-Kevin
Kevin Watson
http://kevin.org
  #250   Spotlight this post!
Unread 18-01-2008, 16:46
billbo911's Avatar
I just saw the answer in encoder.c.
Sorry for the confusion. My bad.
I hate it when I misinterpret instructions like that. Oh well, blame it on sleep deprivation.
  #251   Spotlight this post!
Unread 18-01-2008, 16:48
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Is it recommended to use this code over the default, or should teams wait to use until it's out of its beta stages?
  #252   Spotlight this post!
Unread 18-01-2008, 17:57
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Kevin,
what changes should be made to the Vex C templates to run under 3.10? I'm getting library errors.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #253   Spotlight this post!
Unread 18-01-2008, 18:41
FRC #2429
Kevin,
The library needs to be built with the new compiler. Until then we're stuck with C18 2.4.
-Kevin
Kevin Watson
http://kevin.org
  #254   Spotlight this post!
Unread 19-01-2008, 14:23
Loki1989's Avatar
Loki1989 Loki1989 is offline
AKA: Mike Parker
FRC #5338 (RoboLoCo)
Loki1989 will become famous soon enough
Can we use MPlab 8.0 to use 3.10 to compile? I need to know Because I cant find 7.21
2017 - FRC 5338 RoboLoCo - Mentor
2005-2013 - Team 1544 - One Byte Short
  #255   Spotlight this post!
Unread 19-01-2008, 14:44
kaszeta's Avatar
Yes. That's the exact setup I'm using.
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
