Go to Post Uhh... we were supposed to be building a robot? *looks at giant wooden Trojan Rabbit in the corner that was built instead for the past 6 weeks* Whoops... - Adam Richards [more]
Unread 18-01-2008, 16:58
TERTOLA TERTOLA is offline
FRC #2513
TERTOLA will become famous soon enoughTERTOLA will become famous soon enough
Question More Power Distribution Block Questions
So... We some questions about the power distribution block...
A)How do we connect the power distribution blocks?
B)what gauge wire do you use for them?
Unread 18-01-2008, 17:32
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: More Power Distribution Block Questions
you put the blocks on the din rail that came with the kit.
http://www.usfirst.org/uploadedFiles...on_Diagram.pdf
thats a diagram of the electrical components and how to wire its shows how the blocks go. they all just snap on to the din rail. and you tighten with the screws in the middle.
<R47> All main and branch circuits shall be wired with appropriately sized wire:
-- 12 AWG or larger diameter wire must be used for all circuits protected by a 40A circuit
breaker.
-- 14 AWG or larger diameter wire must be used for all circuits protected by a 30A circuit
breaker.
-- 18 AWG or larger diameter wire must be used for all circuits protected by a 20A circuit
breaker.
-- 24 AWG or larger diameter wire must be used for providing power to pneumatic valves.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 18-01-2008, 23:03
divergentdave divergentdave is offline
FRC #1816 (Green Machine)
divergentdave is a jewel in the roughdivergentdave is a jewel in the roughdivergentdave is a jewel in the rough
Send a message via AIM to divergentdave
Actually, the wires going into the power distribution block (i.e. from circuit breaker or to fuse blocks) should be 6AWG, since they'll only be protected by the 120A breaker.
Team 1816 - The Green Machine
Unread 18-01-2008, 23:09
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Some of the wires in the power distribution block should be 6AWG, but not all of them. For instance, since there is no ground stud on the Maxi block, the ground returns for those circuits go directly to the black power distribution block... those wires are typically 12AWG.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 19-01-2008, 00:41
beemgruem's Avatar
beemgruem beemgruem is offline
AKA: Begüm
FRC #2905 (Sultans of Turkey)
beemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to behold
Yeah, we put 6 gauges for battery and the main circuit breakers connections and the rest of them are 10 just in case.. If I were you I would just use 10AWG.. except the main things for 6..
And for the power distribution block you need the rail..
If you have more questions PM me..
Begüm
Unread 19-01-2008, 23:49
Joe is correct, nice job, Joe. The main circuit breaker, battery, large and small fuse panels all need to use #6 wire per the Power Distribution Diagram. Remember the Power Diagram is referenced in the robot rules. (The heavy weight lines on the drawing are all #6, either red for positive or black for negative) If you choose to use #12 for your 40 amp circuits then the return lines (black wires) should come back to the Rockwell Power Distro Block. The Q&A has responded that you may return these wires to the common buss on the small fuse panels but I recommend against this. When you return all high current lines to the block, they will not add to the voltage drop in the wires feeding the panel. The critical issue is pulling the RC below 8 volts. This is very easily done when you sum currents in your wiring.
Unread 27-01-2008, 13:07
organman42's Avatar
organman42 organman42 is offline
AKA: Jeff
FRC #1073 (The Force Team)
organman42 is an unknown quantity at this point
What is the minimum length for the din rail? I know that it is somewhere, but everybody I have asked can't find it.
"I have a different vision of leadership. A leadership is someone who brings people together."
Unread 27-01-2008, 13:18
interfect interfect is offline
FRC #2022
interfect will become famous soon enough
As far as I know, there isn't a minimum length. It has to be long enough to hold the block on securely.
Unread 27-01-2008, 14:40
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
some pictures of our prototype and our final board
hope this helps!
Unread 27-01-2008, 18:17
These pictures show a correctly assembeld block (as near as I can tell.) You may cut the DIN rail to whatever length you need. You only need to include as many sections of the block as your design requires. The yellow jumpers can be cut to match your configuration. Nice, short lengths of #6 on the input side should be used wherever you can. The gray blocks are needed to hold the assembly together so yes, the three are required. Fan wires can be twisted together to make a neater package.
When in doubt, the Tips and Guidelines document on the First website has assembly instructions.
Power Distribution Block kE7JLM Electrical 4 17-01-2008 08:48
Power Distribution Block.. beemgruem Electrical 21 11-01-2008 08:11
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
