Go to Post Hmmm I think I hear phones ringing. Panic calls to the Rules committee to figure out how to close THAT loophole, which you could drive a truck through. Have you considered a career in Law? - ChrisH [more]
Unread 18-01-2008, 18:01
Mikhail_Pham Mikhail_Pham is offline
Mikhail_Pham is an unknown quantity at this point
Movement of the Fisher Price motors
This is a simple and rather dumb question, but suppose one uses the Fisher Price motors to rotate an arm. If one cuts power, does the arm simply dangle, or is it held in place?
Thank you.
Unread 18-01-2008, 18:04
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Movement of the Fisher Price motors
Thank you.
Simple and rather Dumb Reply: it depends.
How much torque are you dealing with?
Unread 18-01-2008, 18:05
1086wulf's Avatar
1086wulf 1086wulf is offline
AKA: Ian
FRC #1086 (1086 Blue Cheese)
1086wulf is an unknown quantity at this point
It depends on the weight of the arm. If you are holding up something like 10 pounds it will probably fall back down. It would only stay up if it is light and standing strait up.
"You sure know how to throw a party. No food, no drinks, and the only babe just left." Dante DMC3
Unread 18-01-2008, 18:27
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
it really depends on the torque (gear ratio) and your design of lift, rotation, etc. They dont move that easily without power. However, with a 10lb ball to deal with, I'm sure it will not stand still with a loss of power.
This is actually our first year we dont intend on using those motors for our lift.
Unread 18-01-2008, 19:51
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
We use a worm gear type reduction for lifts because they are typically harder to backdrive.
It shouldn't be hard to set up an experiment.
Unread 18-01-2008, 20:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You can put the Victor(s) on "brake" mode which will help a little bit. It might still fall but not as fast. Traditionally worm gear setups don't fall (backdrive). The Van Door motor is the exception.
Unread 18-01-2008, 20:59
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Whether or not a worm gear backdrives is dependent on the angle of the worm. If the angle is less than 5 degrees it probably won't backdrive. More than that and it probably will. This is an approximate number and how your system responds depends on many things including how smoothly your gears turn and how the load is applied.
If I recall correctly, the worm on the vandoor is around 10 degrees. I haven't looked closely at this year's motor, but older versions had an adjusting screw that could be used to increase the drag on the system and reduce a tendency to backdrive. I wouldn't reccommend making it too tight though!
Christopher H Husmann, PE
"Who is John Galt?"
Unread 18-01-2008, 22:59
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
If you wanted to you could put some kind of a passive lift system to hold your arm up. This would be something like surgical tubing, a spring, or closed actuator. Also you can stall the motor by giving it constant power so it doesn't move. Stalling is not good for the motor if it last more than a second or two. The only issue you may encounter with using a worm gear is that when a match is over you may not be able to put the arm down without power.
-Dustin Benedict
Unread 19-01-2008, 05:23
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
If you want it to be stable, use the blue speed reducer transmission... thing.
That's what we did on our robot, and the arm was very stable:
http://www.chiefdelphi.com/forums/sh...ad.php?t=56063
You should be able to see it on the third picture.
Of course, using the speed reducer it DOES reduce your speed along with the vibrations, so think carefully if you really want to have a stable but slow arm, or fast but unstable arm (or something that's half of each).
Hope that helps.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Unread 24-01-2008, 20:25
esisso esisso is offline
AKA: Eitan
FRC #1242 (Team Smiley)
esisso will become famous soon enough
Send a message via AIM to esisso Send a message via MSN to esisso
hey where did u get that blue thing? and how does it work?
Unread 24-01-2008, 21:36
Mikhail,
The simple answer is the Fisher Price even when used with the supplied transmission cannot hold itself in place when the power is removed especially with the weight of the arm and whatever it might be holding. You can couple to a worm gear system as some have discussed or you can use a pneumatic operated brake to hold the arm in place. You can even use a servo motor to operate a mechanical stopper, the choice is up to you.
Unread 24-01-2008, 21:40
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Mikhail,
Another option is to use a Nothin' But Dewalts style gearbox and leave the anti-backdrive pins in.
are this year's fisher price motors as good as the old ones with the black case? waialua359 Motors 2 11-01-2007 22:51
Buying parts for the Fisher-Price motors KrtZer0 Motors 3 11-02-2006 15:22
Fisher price motors connected to the relays? zainali Motors 1 09-02-2004 18:50
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
