Go to Post We discovered this problem on the ship day (sure, when else?) - Manoel [more]
Unread 18-01-2008, 20:15
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
Testing for bits in EasyC
my team wants to use the USB chicklet with the x-box360 controller
in the FIRSTwiki it explains how to test an individual bit in MPLab
I would like to make sure that code like the following is supported in EasyC
#define BUTTON_5 ((~p1_wheel &0x80)!=0)
I think it should work but there might be some obscure reason why it might not
Confirmations with reasons or denials would be great! Thank you in advance!
ALWAYS a mechanical problem!
Unread 18-01-2008, 22:07
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Testing for bits in EasyC
Paul recommend we use
dpad_top = (GetOIAInput ( 1 , 3 )&1<<7)?0:1 ;
dpad_bottom = (GetOIAInput ( 1 , 3 )&1<<6)?0:1 ;
dpad_left = (GetOIAInput ( 1 , 3 )&1<<5)?0:1 ;
dpad_right = (GetOIAInput ( 1 , 3 )&1<<4)?0:1 ;
left_top = (GetOIAInput ( 1 , 4 )&1<<7)?0:1 ;
right_top = (GetOIAInput ( 1 , 4 )&1<<6)?0:1 ;
left_trigger = (GetOIAInput ( 1 , 4 )&1<<5)?0:1 ;
right_trigger = (GetOIAInput ( 1 , 4 )&1<<4)?0:1 ;
I'm not sure how to properly define this so the compiler does barf but if you can do it in C you can do it in easyC
edit: I got it to work I think...
Click on the projects tab and paste:
#define BUTTON_5 ((~GetOIAInput ( 1 , 3 ) &0x80)!=0) // same as p1_wheel
Into UserInclude.h
Also the Xbox controller itself isn't the best unit the thumbsticks stick and don't recenter well. The Logictech "PS2" like controller works better.
pic: Almost ready for testing Doug G Robot Showcase 4 04-02-2006 18:49
How do i connect the camera for testing? naor52 Programming 1 12-01-2006 01:11
Testing Motor for Specs? indieFan Motors 12 07-11-2004 18:36
Budget OI/RC for testing Racer26 General Forum 1 09-07-2004 21:15
Tips for Sensor Programming and Testing EricEnsor Programming 3 24-01-2003 11:28
