Go to Post Don't forget the robot, the most important hardware there is!:p - artK [more]
Unread 18-01-2008, 20:44
NinJA999's Avatar
NinJA999 NinJA999 is offline
Chipmunk NinJA
AKA: Nick Aldwin
FRC #0811 (Team 811)
NinJA999 will become famous soon enough
Send a message via AIM to NinJA999
LCD
My team has purchased an LCD from Scott Edwards Electronics. We will use it for diagnostics on the robot, but I was wondering if there is any way to use the LCD on the OI. That would be wicked cool.
Team 811 (Nashua, NH) - Mentor
Previously Team Lead & Programming Lead
Unread 18-01-2008, 21:00
tanmaker
Posts: n/a
Re: LCD
as long as it can run off of the power provided by the controller, then you should be ok. but no outside power sources
Unread 18-01-2008, 21:23
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: LCD
if you connect it to the dashboard port you can run it off of a separate battery (think of a laptop) you just have to have some kind of controller that can parse the output stream and turn it into something the lcd can read. you justy cant connect it to the inputs on the OI
...forest
Unread 18-01-2008, 22:13
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: LCD
You can find a datasheet on the dashboard if you download the dashboard viewer application from ifi robotics there is a pdf with it that tells you all about the output from the dashboard
Plasma or LCD TV? Wayne Doenges Chit-Chat 10 21-12-2007 14:34
LCD Doesn't work :( magical hands Programming 6 08-03-2007 20:37
LCD monitors robot180 IT / Communications 30 15-06-2006 21:55
3-D LCD Screen Joe Matt Chit-Chat 5 17-10-2002 23:32
LCD display James Crivellone Rules/Strategy 6 06-01-2002 10:22
