Go to Post I check CD while I'm waiting for ProE to reload everytime it crashes. So that's about 20 times a day :ahh: - Gary Dillard [more]
Unread 17-01-2008, 16:36
Kilroy0846 Kilroy0846 is offline
FRC #2139
Kilroy0846 is an unknown quantity at this point
Omni Wheel
Our team recently purchased 6" Aluminum Omni wheels from Andy Mark. I also got the "press fit" 1/2" ID bearings that are recommended for the wheels. When they said press fit I figured heating up the wheels so the bearing would slide in, then cooling it down to get a tight fit. Contrary to my assumption, the bearings slide right in and out of the holes. I was wondering if any other teams had this problem and how you solved it. Or if there is a standard way to solve this problem that I haven't found on the forums yet
Thanks
Unread 17-01-2008, 16:40
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Omni Wheel
You can try loctite and pinning them in.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Omni Wheel
Are your omniwheels going to be powered; e.g., will you mount sprockets on them?
Richard Wallace
since 2003
Unread 17-01-2008, 16:54
FRC #2139
Re: Omni Wheel
no they are free. They just roll on an axel
Unread 17-01-2008, 17:11
Re: Omni Wheel
In that case you could try what Kevin suggested above.
Or, if you need more stability, you could mount a second bearing on the other side of the omniwheel.
The second bearing would go in a plate you would need to make or buy. The plate would need to be at least 2-1/8" in diameter and about 1/8" thick. It would need a 1-1/8" hole in the middle and a pattern of six clearance holes for 10-32 screws (about 0.2" diameter) on a 1.875" diameter circle. The plate would mount to the omniwheel using spacers, maybe 1/4" long, which would accept 10-32 screws.
The two bearings will both tend to fall out if you don't support them laterally on the inner races, so you'll need some kind of axle bushing on each side. But you'd need that anyway, to keep the omniwheel from sliding along the axle. I've seen axle bushings made from 1/2" inside diameter PVC or other kinds of pipe.
Richard Wallace
since 2003
Unread 17-01-2008, 17:21
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: Omni Wheel
We make an aluminum part that holds the bearing in. This goes over the lipped side, holding it to the omniwheel.
Hi!
Unread 17-01-2008, 18:15
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
Re: Omni Wheel
We just made spacers to go between the bearings and the frame on both sides.
Unread 17-01-2008, 18:53
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: Omni Wheel
Thanks
Are all AndyMark Plastic Omni wheels designed to have a loose press fit ? Or do other teams have a tighter press fit ?
Why would you not want a tight press fit similar to the Kit Wheels ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 17-01-2008, 19:54
Xenozero Xenozero is offline
Xenozero
AKA: The inovator
FRC #1230 (Lehman Lionics)
Xenozero will become famous soon enough
Send a message via AIM to Xenozero
Re: Omni Wheel
my team is having a similar issue, we have never used the omni wheels before. We purchased 2 omni wheels and 2 22 tooth sprockets to mount on them, but the bearing just slides right out. After some of the mentors got on the phone with the supplier, they tell them that they are designed to be used in pairs with their "omni spacers" is this true ?
Unread 18-01-2008, 00:15
FRC #2139
Re: Omni Wheel
Thanks fellas
you helped out a lot.
Unread 18-01-2008, 07:44
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Omni Wheel
We are using the 6" aluminum Omni's and we are getting 7/8" OD flanged bearings to keep them from Falling through.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 18-01-2008, 21:19
aksimhal's Avatar
aksimhal aksimhal is offline
AKA: Anish
FRC #1123 (Autodidactic Intelligent Minors)
aksimhal is an unknown quantity at this point
Send a message via AIM to aksimhal
Re: Omni Wheel
I know this is somewhat random question for this thread, but where are about 6" omni wheels sold besides AndyMark. (They are sold out of Aluminum wheels).
Thanks,
Unread 20-01-2008, 22:53
Lawry Goldstein Lawry Goldstein is offline
FRC #1525
Lawry Goldstein is an unknown quantity at this point
Re: Omni Wheel
We used AndyMark omni wheels last year, and we have AndyMark onmiwheels, performance wheels, and Gen2 Shifters this year as well as the ToughBox, all of them have bearings that easily slide in and out of their mounts.
I assume this is on purpose, bearings in industrial applications generally require an arbor press to seat, and then a bearing puller to remove, since many teams lack one if not both of these devices, such a fit is an advantage for most FIRST teams as the cost of efficiency and stability which is immeasurably and unnoticeable for most teams.
If the stability gained from a properly seated bearing is part of your design, you’re probably making most of your drivetrain yourself, so it makes sense to me.
Unread 20-01-2008, 22:58
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Omni Wheel
haha, that was pretty much our approach. Except we just used some scrap aluminum sheet and the hand mill and only had three holes. your's looks nicer though
-vivek
"we don't build robots, we build people"
Unread 20-01-2008, 23:09
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: Omni Wheel
Thanks,
Honestly I don't know of anywhere else to buy them. Most teams used to just machine them, so I think AM may be the only supplier. Are the plastic ones sold out too??
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
pic: Poor Man's Omni Wheel Sean Schuff Extra Discussion 11 24-01-2006 22:48
omni wheel instead of mecanum wheels Leav Technical Discussion 4 15-01-2006 18:53
Omni-Wheel Design fightoplankton Technical Discussion 7 08-01-2006 23:49
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 05-12-2005 10:38
Omni wheel supplier JamesBrown Technical Discussion 5 25-02-2005 13:27
