Go to Post Oh End-Of-The-World CDenizens... you never fail to entertain... - JesseK [more]
Unread 18-01-2008, 22:49
fhsteam613 fhsteam613 is offline
FRC #0613
fhsteam613 is an unknown quantity at this point
Weighing the Robot
Last year we were a little bit more than 30 lbs overweight . The guys at the weighing station said that in all their years they have never seen anyone so horribly overweight . Needless to say, we spent the next day and a half tearing everything we possibly could off of our robot.
In an effort to thwart the repetition of past events, we would like to find a way to weigh our robot as we go along. I was personally looking into buying a scale meant for people in wheel chairs, but then i found out they run between $450-2,000. There has got to be a cheaper way to weigh the robot without dishing out so much money. Just to clarify, I am looking to weigh the robot as a whole, not one part at a time. Any methods or general ideas are welcome!
Thank you,
Evan Shegoski
Unread 18-01-2008, 22:50
Cooley744's Avatar
Cooley744 Cooley744 is offline
Cooley744
AKA: Lauren
FRC #0744 (Shark Attack)
Cooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to behold
Send a message via AIM to Cooley744
Re: Weighing the Robot
drive your robot into publix and put it on the scale! lol
For whatever you do, work at it with all your heart, as working for the Lord, not for men.
Colossians 3:23
Proud graduate and now lead strategy mentor and driving coach for 744 Shark Attack.
Unread 18-01-2008, 22:54
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
Last year we were able to find someone who owned some car scales (the kind where there's 4 seperate parts, 1 for each wheel). I assume they were very expensive, but if you know anyone who is a mechanic or works with cars, see if you could use their scales.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 18-01-2008, 22:56
For starters, weight one part at a time and add them up. For sub-assemblies, try a fish scale. Get one that can take a lot of weight. For the full robot, use a bathroom scale with something on top to hold the robot (if you can).
Unread 18-01-2008, 22:58
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Our rookie season we didnt concern ourselves about weight until the last day or so. We knew a person that had a scale used for weighing larger shipments, so we borrowed it. We found out we were about 40 lbs overweight! That night we had three people just going at it with hole saws getting rid of weight. Our robot was almost completely clear that year and the holes were straight, so it really didnt look to bad. We later named it the "Holey Roller". We got to the competition and found that we were JUST over. We took a sawzall to the back of it, which we now call the shotgun hole, or the battle wound. We got it under, but if we would have kept track of weight, we could have avoided all that. Ou next year we did, and were about 20 lbs under. Weight does matter, and sorry taking out white space in the code does not really work.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 18-01-2008, 23:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Start out the season by learning how to calculate the weight of parts, such as aluminum and steel and plastics and whatnot.
Aluminum weighs 0.10 pound per cubic inch.
Steel weighs 0.28 pounds per cubic inch.
Plastics mostly weigh about 0.05 pounds per cubic inch.
Weight the other parts like motors and transmissions and chains and stuff on a small scale...are there any in your science rooms? or the mail room?
Make a weight budget, starting with the chassis and electronics and pneumatics, the stuff that HAS to be on the robot. Then figure out how much weight you have left over for the rest of it, and if your design weighs too much, then you need to change your design before you start building it!
Unread 18-01-2008, 23:07
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
When you CAD, set all of your material properties
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 18-01-2008, 23:09
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
I have, and solidworks refuses to tell me the mass of multiple parts in an assembly at once.
And I don't put the bolts in my assemblies.
Unread 18-01-2008, 23:15
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
If you are at a school you most likely have a doctor's scale in a nurses office or in the phys. ed. dept. for wrestling, etc...you can actually weigh the front of your robot (with wheels resting on boards or stock metal laid across the base plate you stand on) while the rear wheels rest on a stack of stock/ boards on the floor and level with the front rests...record the weight minus the boards/stock that was on the scale's base plate and then turn the bot around carefully and weigh as you first did (minus the support stock/boards weight of course)...just add the two weights up and you are set! We have always been within a half pound of the expensive scale used at the competitions...this is of course a way to tell total weight but it is better to weigh and record components before you assemble and again a typical scale will get you decent weight information...
Unread 18-01-2008, 23:17
MrForbes's Avatar
AKA: Jim
We usually set two 2x4s across a medical scale, set it to zero, then set the robot on, and it reads pretty much exactly what the scales at regionals do.
Unread 18-01-2008, 23:24
MasterMkanik's Avatar
MasterMkanik MasterMkanik is offline
AKA: Cameron
FRC #0619 (CARobotics)
MasterMkanik is an unknown quantity at this point
Two years ago (Aim high) we were forty pounds overweight three days before ship date, we litteraly took a sawsall and cut two feet of our robot, as well as taking out every other bolt. remember to account for all your nuts, bolts and washers as well!
He's on the Fruit Loops side of the cereal aisle... if you know what I mean.
My mind works like lightning, one brilliant flash and it's gone
Unread 18-01-2008, 23:29
CraigHickman
Posts: n/a
We bought a wrestling scale. Then we put two Aluminum 2x4 box extrusion bars across it, and zeroed it. Once that's done, you're left with a nice little platform to put the robot on.
Unread 18-01-2008, 23:32
Devon27 Devon27 is offline
FRC #0027 (Team Rush)
Devon27 is an unknown quantity at this point
in years past, we borrowed the scale from the wrestling team, put a couple 2x4s across it (for the weels to be on), zeroed the scale and then put the robot on. This year, we invested in a scale our own so we won't need to borrow one anymore.
Devon -- Team RUSH 27
2009
Kettering District Event Entrepreneurship Award, Lansing District Event Chairmans Award, Michigan Chamionship Chairmans Award
2008
Detroit Regional Finalist, Detroit Regional Chairmans Award, Great Lakes Regional Motorola Quality Award, Championship Motorola Quality Award
2007
Detroit Regional Entrepreneurship Award, West Michigan Regional Chairmans Award, West Michigan Regional Entrepreneurship Award
RIP John Lafata--Forever 27
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
675 calculates (egads)
we also use a bathroom scale to verify. Works well for us. Last year, before ship, we were just under our max height, just under our max dimensions, just under max weight. It owned.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 19-01-2008, 00:51
Gertlex's Avatar
Alumni and mentor
AKA: E Relson
I forgot to mention how my team weighs stuff
We have a combination bed lift/scale that we have had on permanent loan from our high school's nursing classroom for the past few years. It works quite nicely via slinging the robot in rope or some such.
Part Four: The FIRST Robot Rock Opera: The Robot Rebellion Gabe Salas Jr. General Forum 0 14-03-2007 17:57
From the Ice Age to Robot City. The Few, The Proud, The Machines (new movie) Elgin Clock Televised Robotics 21 14-03-2005 15:14
Weighing your Robot Nitroxextreme General Forum 18 13-02-2005 22:21
Rambot weighing in at 72.5 lbs! archiver 2001 3 23-06-2002 22:04
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
