Go to Post Action x (Passion Vision) = Goal - EricH [more]
Unread 18-01-2008, 23:38
master_nickz master_nickz is offline
FRC #2169
master_nickz is an unknown quantity at this point
Hybrid Question
Just a brief query-
Does anyone know if it is legal to block the track during hybrid mode with your robot to prevent robots on the other alliance from obtaining lines?
2007 Wisconsin Regional Champions
2007 Galileo Division- 16th place
Unread 18-01-2008, 23:49
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Hybrid Question
The bump-to-pass rule is not in effect in hybrid mode. As such, I don't believe you can be flagged for impeding traffic. However, you won't be able to block the lane all that much, since you can only extend to 80".
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 18-01-2008, 23:53
FRC #2169
Re: Hybrid Question
Yes, you are correct about the fact that we couldn't take up too much space. I was just curious. Thanks so much for your help!
Unread 19-01-2008, 00:24
Best Available Data
FRC #1778 (Chill Out!)
Re: Hybrid Question
Who says a blocker needs to be everywhere at once? As long as you can see 'em coming you can get in their way.
Of course, you'll want to think this through strategically. Is it likely that the other alliance will cross both of their lines and get to where you're blocking? Is it likely that YOUR alliance will get to that point, at which point you'll be in the way? Are you confident enough in your robot (both mechanically and in programming) that you won't go over the line and get a penalty for going against traffic? Is it more worthwhile to go after the 4 easy, and 8 doable points? Or is it a good thing to have a defensive autonomous to pull out of your bag 'o tricks, should it become necessary in the final rounds? All things to think about...
Hybrid mode? Mrtrom General Forum 20 21-01-2008 07:11
Hybrid mode question. ks_mumupsi Rules/Strategy 13 14-01-2008 22:43
Hybrid mode issue Los Frijoles General Forum 2 07-01-2008 18:52
pic: VEX hybrid John Gutmann Extra Discussion 3 01-02-2007 12:08
Question About Threaded/Hybrid View Ian W. CD Forum Support 2 07-12-2003 23:18
