Go to Post When I first read this comic, I thought "Awww, how cute!". But then, thoughts of Karthik singing J. Lo's "Love Don't Cost a Thing" started running around through my head, and everything changed. - Travis Hoffman [more]
Unread 18-01-2008, 22:55
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Best way to remove fisher price pinion???
Anybody out there know the best way to safely remove the 19 tooth pinions on this year's fisher price motors? The pinion remover sold by banebot sure doesn't do the trick!
Unread 18-01-2008, 22:59
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
Re: Best way to remove fisher price pinion???
I would recommend not using a grinder or saw. We went to the mobile machine shop at Championships last year and they had to use the two because they didn't have a puller.
It did not end very well...
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 18-01-2008, 23:17
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Try using a nut splitter referred to in this thread about getting the pulley off of the large cim.
http://www.chiefdelphi.com/forums/sh...lley+large+cim
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 18-01-2008, 23:25
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
We use a pin that is slightly smaller than the shaft and then use an arbour press to take it off. It works real well for us, I just did some fisher price motors the other day and had no problems.
-Josh Murphy-
Unread 18-01-2008, 23:31
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
You asked for the best way, and Dremeling certainly isn't it, but it works if you're careful. We succeeding in taking off a few pinions this way in 2006.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 19-01-2008, 02:46
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
I tried using the banebots puller last night as well and after dremelling off some of the pinion teeth just to get it to fit, we tried the puller, and it just bent.
Next I tried using a drill press, and put the banebots puller pin in the chuck, and tried pressing out the shaft and the drill press setup was just not rigid enough.
Finally, I had to take the motors to the machine shop at school and use their arbor press, which did work since it was a more rigid setup.
But, while I was using the drill press method, I accidentally slightly bent the shaft on one of the motors. Anyone have a link or know how to buy more?
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 19-01-2008, 02:56
MasterMkanik's Avatar
MasterMkanik MasterMkanik is offline
AKA: Cameron
FRC #0619 (CARobotics)
MasterMkanik is an unknown quantity at this point
My method is just get a bigger hammer.
He's on the Fruit Loops side of the cereal aisle... if you know what I mean.
My mind works like lightning, one brilliant flash and it's gone
Unread 19-01-2008, 02:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Joe,
I too was unhappy to find that the banebots puller is useless, after buying it specifically for that purpose.
We made a plate awhile ago we use to remove it. It's a 1/2" thick aluminum plate, with a slot in it that goes most of the way through the depth of the plate, just wide enough to clear the pinion gear. We then mill a second through slot in the middle of this slot that acts as a clearance hole for the motor shaft.
You can then slide the motor onto the plate, and use an arbor press with any sort of pin to push the pinion off of the motor.
This has worked pretty well for us.
2001-2004: Team 100
2006-Present: Team 254
Unread 19-01-2008, 03:11
AdamHeard's Avatar
Lead Mentor
Originally Posted by Cory View Post
Joe,
im having trouble visualizing this..... can you post a picture?
Unread 19-01-2008, 03:13
Engineering Mentor
Joe,
How do you fit a 1/2" plate underneath that little pinion? We only have about 3/16" of space or less.
Unread 19-01-2008, 03:17
Cory's Avatar
AKA: Cory McBride
I'll go take one right now.
2001-2004: Team 100
Unread 19-01-2008, 03:28
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
We made a plate a while back, and while pressing off a few FP pinions we bent the 1/2" plate!
We have since used a nut splitter/buster and would never use the pressing method again. The nut splitter works with a vice and and end wrench and snaps it off everytime without damaging the shaft. Can't reuse the pinion though...
You can get these at most hardware stores (Kragen, Napa, autozone, etc)
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Cory's Avatar
AKA: Cory McBride
Ok, these are admittedly horrible pictures, but the lighting on my workbench is terrible.
The first shows the top view. You can see the large slot. The second shows a side view where you can see the second slot going all the way through the plate. It's currently occupied by a zip tie, but you get the point.
[edit] Just saw Travis' post. We too just use a nut buster, unless for some reason we need to reuse the pinion. In which case we use the plate. We also bent/broke the first plate we made.
ID:	6058  Click image for larger version
2001-2004: Team 100
Unread 19-01-2008, 09:47
AKA: Joe Barry
Thanks for the great ideas, Cory, Travis and others...now if we could just find a source this year for fp motors Team 987 will be in great shape and looking forward to seeing you guys in Atlanta.
Unread 19-01-2008, 18:03
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
The easiest way is to simply point a heat gun at the pinion gear. Just pops right off.
Fisher-Price 00968-9012 motor pinion Joe P Motors 3 03-04-2007 19:31
fisher-price pinion gear bill mc gowan Motors 6 06-03-2006 11:14
Fisher Price Pinion Pressure Angle alphastryk Motors 1 04-02-2006 21:06
Fisher Price Gearboxes Nathan Pell Motors 7 06-03-2004 11:29
Legal way to remove bottles? and other questions jrukes Off-Season Events 4 15-10-2001 22:35
