LINKING ERRORS!!!
Hey guys, when we compile our code in EasyC, we get a linking error and the error says: Error- section '.code_u2open.o' can not fit the section. Section '.code_u2open.o' length=0x00000064. We're dividing with floats and that seems to be the problem because it works with ints. Any ideas???
Re: LINKING ERRORS!!!
You've run out of Program Memory on the controller.
If you need those decimals, you could just scale them up by a few factors of ten so you can use ints, divide, then scale it back down.
It'll be faster too. |
Scale up by factors of 2. Then you can use << instead of *. It's a heck of a lot quicker. You still have to divide unless you're using unsigned ints, however.
Alright thanks guys, helped a lot and we're back on track now!!!
| linking error | Turdmoe | Technical Discussion | 2 | 27-01-2007 19:01 |
| Error Linking for '05 RC | Jon236 | Programming | 2 | 12-02-2006 14:30 |
| A linking problem | T Shap | Programming | 6 | 15-01-2006 00:23 |
| Linking Errors: "section '????' can not fit the section. ..." | Astronouth7303 | Programming | 3 | 16-01-2005 21:36 |
| Dynamic Linking with PHP | plutonium83 | Website Design/Showcase | 6 | 12-01-2005 19:41 |
