Go to Post If you want to have other teams cheer for you all day long at competition, name your team "Robot Coming Through". - Gary Dillard [more]
Unread 19-01-2008, 11:55
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Question 80 inches
In the 80 inch rule, does the ball have to be included in that 80 inches as well, or not since it is the game piece? \
Thanks
Unread 19-01-2008, 12:05
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
Re: 80 inches
The ball does not count towards the 80" limit.
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 19-01-2008, 12:13
AKA: Mitch guzman
Question Re: 80 inches
so then, if our robot itself can go past 80 inches, but we don't, are we disqualified?
Thanks
Unread 19-01-2008, 12:26
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: 80 inches
The 80" rule is enforced on the field in the "Playing Configuration". This means that as long as your robot does not exceed a maximum 80" horizontal measurement while playing the game you will not receive a penalty. Also, unless you frequently violate this rule you wouldn't be disqualified you would only receive a 10 pt. penalty.
<R16> Once the MATCH has started, the ROBOT may assume a PLAYING CONFIGURATION that
exceeds the size dimensions specified in Rule <R11>. While in the PLAYING
CONFIGURATION, the ROBOT may expand up to a maximum horizontal dimension of 80
inches (e.g. all parts of the ROBOT must fit within an imaginary 80-inch-diameter upright
cylinder). There are no height limits for a ROBOT in its PLAYING CONFIGURATION at any
time after the start of the MATCH.
And remember the 80" cylinder is an example not part of the rule itself.
Unread 19-01-2008, 16:33
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: 80 inches
Why would they "e.g." instead of "i.e."?
"e.g." means "For example…"; "i.e." means "meaning…".
Am I missing something here?
Unread 19-01-2008, 18:05
GaryVoshol's Avatar
Cogito ergo arbitro
Re: 80 inches
Because it is an example, not the literal meaning of the rule. This was explained in one of the updates - #3? Someone in one of the other threads regarding <R16> noted that an equalterial triangle with 80" sides would not fit in an 80" circle.
(since 2004)
Unread 20-01-2008, 00:01
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: 80 inches
Everyone should read this regarding the 80" rule:
http://forums.usfirst.org/showthread.php?t=8159
This was definitely different than my initial interpretation when I read the rule.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
4 inches vs. 1 foot Golfer241 Technical Discussion 24 15-02-2007 00:42
pic: 2004 Robot+ 2 Ringers= 12 inches 358_4_Life Extra Discussion 5 16-01-2007 08:11
pic: 612 rollin on 6 inches Priyadarshy Extra Discussion 6 12-10-2006 15:46
