Go to Post No one ever said that this was easy. - Jaine Perotti [more]
Unread 19-01-2008, 11:41
KLoiselle KLoiselle is offline
FRC #1649
KLoiselle is an unknown quantity at this point
Mounting Gear Counters
Our team is looking for anyone to help us/point us anyway to be able to mount the gear counters that came in this years KoP. We are using the gearboxes that came in the KoP, the toughboxes, and we have found information about wiring but are not quite sure how to place the gear counters in the gearboxes.
Unread 19-01-2008, 12:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Mounting Gear Counters
You can find some information about mounting the Gear Tooth Sensor in this thread:
Problem Mounting Gear Tooth Sensor
Unread 19-01-2008, 13:23
FRC #1649
Thank you.
Mounting the Gear Tooth Sensor??? blue_crew Electrical 3 09-02-2006 13:53
HELP!!! Counters, global variables, and the like danielkitchener Programming 2 23-02-2004 23:53
mounting of the small gear directly to the shaft of the drill Andrew Dahl Motors 0 19-01-2004 12:18
counters iBob Website Design/Showcase 4 02-03-2003 13:02
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
