Go to Post We have a lot of rookies, and I can't wait to see the inspiration on their faces. - Karibou [more]
Unread 18-01-2008, 16:02
scottcook scottcook is offline
FRC #1717
scottcook is an unknown quantity at this point
Cable for forklift mechanism
our team has never used a forklift mechanism before and we have seen people use chains and cables. Could someone recomend the type and size of cable that would be best for this?
Unread 18-01-2008, 16:05
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Cable for forklift mechanism
spectra cable
http://www.smallparts.com/products/descriptions/mcs.cfm
the stuff is stronger than steel wire but sunlight weakens it. (just dont go in the sun ) crazy strong...
-vivek
"we don't build robots, we build people"
Unread 18-01-2008, 16:13
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
If you are talking about how to lift it through a motor driven system, then #25 chain or belting like what was included in the kit (gates).
If you are talking about the cable to lift the sections, I would recommend 1/8" or bugger steel cable. You don't want any stretch. It is fairly easy to work with, but you will need ferrules and other conectors to get it tight the first time.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 18-01-2008, 16:43
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Preselected cable works wonders if you can afford it. Aircraft Cable will do the trick on anything.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 18-01-2008, 16:50
in between teams
AKA: Luke Van Oort
We have had problems with cable based systems, but not with chain driven (mind you, we've only done one of each, so that isn't a very large sample set). With chain driven systems, all you need to do is toss on a sprocket instead of having to build a drum to wind the cable up on and you don't have to worry so much about slippage.
Team 1219: 2009 - Mentor
Unread 18-01-2008, 17:11
cardinalman86's Avatar
cardinalman86 cardinalman86 is offline
0001 0101 0010 1001 System Lead!!
AKA: Corey
FRC #1529
cardinalman86 will become famous soon enough
Send a message via Yahoo to cardinalman86
three years ago we used 1/4" cables and we didn't have any problems with it. it still worked 'til last year when we used it to prototype. personally i think that chain is better, but it's only a preference.
Before you practice zen, a bowl is a bowl and a cup is a cup. During zen, a bowl is not a bowl and a cup is not a cup. After practicing zen, a bowl is a bowl and a cup is a cup.
Unread 18-01-2008, 17:15
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
would what came in the gates bag be a good idea?
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
Unread 19-01-2008, 12:53
Dick Linn's Avatar
no team (Synergy)
It depends on your lifting mechanism and the load. One year, we used 3/16" or 1/4" nylon rope to operate a list mechanism. Another team used some nylon strap webbing, perhaps 1 inch wide by 1/16" thick. That stuff spooled up nicely.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 19-01-2008, 13:51
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
the best solution we have found are the gates belts, they work great (although pricey) and can hold and move a large load with minimal stretch. verry fast to put together as well
Motor for a forklift calvin1631 Motors 7 10-01-2008 11:30
Cable/winch vs. chain for telescopic arm VEN Technical Discussion 9 20-01-2007 22:37
Bluetooth replacement for programming cable? EHaskins Programming 13 26-07-2006 03:50
What kind of material will you be using for your arm/forklift? Atman Technical Discussion 35 31-01-2005 15:28
PWM Cable Clip for Victors sanddrag Technical Discussion 9 18-07-2004 19:27
