Go to Post I can't really think of a bad FIRST experience, really, I can't. - Joshua May [more]
Unread 18-01-2008, 21:59
bsbllpss's Avatar
bsbllpss bsbllpss is offline
[RockStar]
AKA: RJ
FRC #2044 (Big Red Robotics)
Team Role: Electrical
bsbllpss is an unknown quantity at this point
Send a message via AIM to bsbllpss
fans on victors
I have a question. To some it may seem stupid. Our we absolutely recquired by rule to use a fan on every victor? Even if there's more than adequate ventilation near the victor?
Unread 18-01-2008, 22:01
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Re: fans on victors
I think you will burn it out if you do not use it. They make is a ton of heat when running your bot a lot.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: fans on victors
Honestly, I don't know if there is a rule requiring it, though there may be. IMHO, if you want to make more than one lap, you will use them.
Unread 18-01-2008, 22:03
bsbllpss's Avatar
[RockStar]
AKA: RJ
Re: fans on victors
I've run the 'bot alot without the fans on the victors, though there is quite alot of mini-duct fans around and near the victors just none on top of them. I've also seen quite a few people saying that they've done fine running w/o them.
Unread 18-01-2008, 22:40
beemgruem's Avatar
beemgruem beemgruem is offline
AKA: Begüm
FRC #2905 (Sultans of Turkey)
beemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to behold
Re: fans on victors
I would just wire it in case, actually I did just in case
This link shows how to wire it also..
http://www.ifirobotics.com/docs/ifi-...al-9-25-06.pdf
I hope it would be helpful..
Begüm
Unread 19-01-2008, 00:24
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: fans on victors
You will not pass inspection without a fan on every victor they are required buy FIRST....
For testing though they are not needed we run them under load all the time with no fan and have had no problems!
Unread 19-01-2008, 00:38
Best Available Data
FRC #1778 (Chill Out!)
Re: fans on victors
Section 8 "The Robot"
If that was a rule, it would be contained within the text of that document. It is not.
Futhermore this Q&A specifically states it is allowed, just NOT a very good idea.
However, in my opinion it is a bad idea to remove them for two reasons. The obvious one is cooling, the other is that they are another line of defense against the magic smoke. Actually, it probably doesn't even work that well at protecting from falling aluminum, but it makes me feel secure.
Unread 19-01-2008, 00:45
popo308's Avatar
AKA: Brent
Re: fans on victors
Sorry i guess i should of read the rule a little closer in previous years i believe we were told to put a fan on victors with no fans.... (could of been a diff team) but i was almost positive they required them...
Yet again rules change year to year
Unread 19-01-2008, 00:49
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
Re: fans on victors
As one of our electronics mentors put it, if the Victor needs a fan, something is wrong. They will run cool without the fan. But yes, it is a bit safer.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 19-01-2008, 15:08
DonRotolo's Avatar
Back to humble
FRC #0832
Re: fans on victors
Not exactly true. The Victor should have a large heat sink, but doesn't, and instead the heat is managed by a fan. WQithout the heat sink (and without a fan) the Victor must be severely derated.
Don
Unread 19-01-2008, 17:07
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: fans on victors
I've run victors with out fans in many of my non FIRST related uses. They don't get nearly as hot in typical use as you might believe.
In the past an inspector noticed that one of the fans on a victor wasn't running on a 95 'bot, and required that it be replaced before passing us. It seems this year that it is not a requirement. I would bring this Q&A with you if you do plan on removing any of the fans. Some inspectors may view it as modifying supplied electronics.
So, if it were my call, I would remove the fans on low current motors and leave them on drive motors and such. Over the course of a two minute match something like a seat motor just won't be able to overheat a Victor. A small CIM motor, however, might.
-Andy A.
Unread 19-01-2008, 17:17
Drwurm's Avatar
Electrical Alumni
Re: fans on victors
The main thing here, is that it doesn't take much to outfit the Victor with a fan. Just run the fan wires down to the victor screws and you're done. They don't use much power, and they'll keep your 115 dollar controllers a bit cooler.
Unread 19-01-2008, 17:25
mta mta is offline
FRC #1896
mta has a little shameless behaviour in the past
Re: fans on victors
why would you not use the fans? they only take like, one inch of space and they keep your bot safe. new victors are EXPENSIVE. So just be safe.
~Team 1896
Unread 19-01-2008, 17:31
Getting old
FRC #0095
Re: fans on victors
~Team 1896
The fans are, however, heavy. Removing fans that are not doing anything useful can shave off some weight. Every ounce counts.
Believe me, in past seasons being able to remove a couple fans would have saved a lot of effort and hole drilling on my part.
Unread 19-01-2008, 20:10
bsbllpss's Avatar
[RockStar]
AKA: RJ
Re: fans on victors
our electronics box is the reason why we're removing the fans
there is not enough clearance with the fans on
the box is outfitted with plenty of fans around the sides so there will be plenty of ventilation
Muffin Fans DavidGitz Electrical 11 19-02-2007 11:43
Muffin Fans lizs702 Technical Discussion 1 21-02-2004 12:26
Muffin fans .. Mike Hendricks Electrical 4 19-02-2004 19:26
Computer Fans Ian W. Electrical 2 04-02-2003 21:22
Fans srjjs Kit & Additional Hardware 0 09-01-2003 22:31
