Re: How do you attach a pulley to extruded aluminum?
You mean with a T-nut? That would be ideal, except we have a limited number of T-nuts... Is there an alternate way?
Go all the way through and use another type of nut, maybe.
Sweeeeeet. Thanks
t nuts are cheap. but you can just get a regular nut that fits back there and use that. if not. drill through all of it and use a bolt
| [OCCRA]: extruded aluminum | bernieseaholm | OCCRA Q&A | 1 | 19-09-2007 21:04 |
| 80/20 Extruded Aluminum | MTA Gearheads | General Forum | 8 | 20-01-2007 19:10 |
| T-Slot extruded aluminum | blue_crew | Technical Discussion | 18 | 29-01-2006 13:05 |
| Mini extruded aluminum | Ravi U | Technical Discussion | 7 | 17-01-2004 02:12 |
| How do you attach a wheel to a shaft? | SilverStar | Technical Discussion | 21 | 21-01-2003 19:52 |
