Go to Post It is not your banners that make you nor the trophies that line your walls. It is the willingness to be brave in the face of defeat and compassionate in the winds of victory that create you. - MysterE [more]
Unread 19-01-2008, 16:12
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
Using WPILib
To get our Ultrasonic sensor to work properly, our team started using WPILib. It works great, and we've also managed to successfully port our four different drive methods. However, I have some concerns about the autonomous period. So far, it looks like that method Autonomous() is only called once. First of all, is this the case, and should it be working that way? If not, is it a hardware or programming issue (we're using an old board and OI, and a not-quite-working competition switch, so it could be either)?
To resolve this problem, in our Autonomous method we're adding a loop as follows:
autonomous(void){
     while(IsAutonomous()){
          DoSomething();
I've been reading on Chief Delphi that if a loop goes on for too long, it can time out and disable the robot. Will that happen here, or does WPILib itself take care of switching between the method and sending/receiving info? If so, anything I can do about it?
Thank you so much for your help.
Unread 19-01-2008, 17:15
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: Using WPILib
The Getdata in WPILIB is done at interrupt level as part of the system clock. This prevents the master processor from shutting you down and allows the user code to loop essentially forever without having to periodically check for new rx data packets.
As part of the same system clock interrupt service routine, when autonomous period ends, then the code forces a warm reboot and this automatically kicks the code out of autonomous code and restarts the code back through main. So the autonomous routine should be able to loop forever and appear never to return on its own via a coded return path.
At least that is how I remember it when I last looked at it.
WPILib and Eclipse Guy Davidson Programming 31 02-04-2008 16:59
WPILib Op. Control mode Dkim Programming 3 10-02-2007 09:19
WPILib Questions Kruuzr Programming 1 22-01-2007 11:46
Using WPILib on a Vex robot koenig3456 Programming 2 02-05-2006 14:56
