Go to Post robots like to give you troubles... its like they have a mind of their own. - hayleybayley217 [more]
Unread 19-01-2008, 15:52
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
pic: A closup view of our prototype worm-crab drive system.
Unread 19-01-2008, 15:53
elvin23's Avatar
elvin23 elvin23 is offline
not cool
FRC #0354 (354)
elvin23 can only hope to improve
Send a message via AIM to elvin23
Thumbs up Re: pic: A closup view of our prototype worm-crab drive system.
how does it work? i like the simple design
I never was a cool guy but i would like to be like the guy in the pic he's cool
Unread 19-01-2008, 16:00
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
I remember last year you had some killer swerve drive. Is this basically the same thing?
I believe the keyang is connected to the cables which rotate the wheel modules.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 19-01-2008, 16:03
CraigHickman
Posts: n/a
This is their 2007 bot. It works by a worm gear driving the wheels, with a cable-turning system. Quite the cool bot, I must say.
Unread 19-01-2008, 16:20
DonRotolo's Avatar
Back to humble
FRC #0832
Schweet!
I like how you use a worm drive to power the wheels from CIMs
Don
Unread 19-01-2008, 16:27
AndyB's Avatar
AKA: Andy Burchardt
Glad to see this get brought back up.
Each gearbox has a vertical CIM motor with a worm on the end. It turns a spur gear that is connected to the output axle that the wheel is mounted on. The whole gearbox sits in a UHMW block that we added grooves to for cables to run through.
The UHMW blocks sit on a 1/4" thick aluminum plate attached to the frame. Each of these blocks are tied together using cable that is wound around another UHMW pully that is connected to the window motor.
When the window motor turns, so do the gearboxes. Here are some links to more pictures of this drive.
http://www.chiefdelphi.com/media/photos/28616
http://www.chiefdelphi.com/media/photos/28615
http://www.chiefdelphi.com/media/photos/28499
http://www.chiefdelphi.com/media/photos/28498
http://www.chiefdelphi.com/media/photos/28612
This is last years drive keep in mind. Not this years.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 20-01-2008, 00:02
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
I'm impressed! Very nice design! Kudos! Wish I had thought of this one!
Steve
pic: Cooney 269's Worm Crab Gearbox Interior AndyB Extra Discussion 11 28-04-2007 18:48
FRC 269 Worm Crab 2007 Video Ricky Q. Robot Showcase 3 21-02-2007 20:59
pic: Coaxial Crab drive CraigHickman Technical Discussion 1 21-06-2006 16:03
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
pic: 217 Gen 2 Crab Module Section view CD47-Bot Robot Showcase 2 28-04-2003 18:26
