Go to Post I think candids are my best... I'm sneaky with my 12X optical zoom. - MissInformation [more]
Unread 19-01-2008, 17:20
NinJA999's Avatar
NinJA999 NinJA999 is offline
Chipmunk NinJA
AKA: Nick Aldwin
FRC #0811 (Team 811)
NinJA999 will become famous soon enough
Send a message via AIM to NinJA999
2005 Compatibility
Our team's Robot Controller is currently not working (see http://www.chiefdelphi.com/forums/sh...d.php?p=681702), and while we send it away for warranty repair we are considering testing code on an old 2005 RC. I read on the FIRSTwiki that the only change from 2005 to present is a new PIC. Looking up this new PIC, I found out that it has a bit more memory. Does anyone know any other differences that might prevent us from using it temporarily?
Thanks,
Nick
Programming Lead
811
Team 811 (Nashua, NH) - Mentor
Previously Team Lead & Programming Lead
Unread 19-01-2008, 17:37
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Re: 2005 Compatibility
It is pretty easy to complie the software using the PIC8520 in place of the PIC8722.
If you are using MPLAB, there are a few things you need to do.
#1: Make sure you select the 8520 device under <Configure>>Select Device.
#2: If you have the 8722 Library, AltTimers, and Linker files included in your project, Remove them. You will need to replace these with the same 8520 version files. If you do not have these files in c:mcc18 folder, Try Kevin Watson's software depository. You may have to look at the archived files from 2005.
#3: If your program has grown beyond the memory limitations of the PIC8520 processor, try removing unused code to get it within the memory available. If you are over, it will not compile.
EDIT: You may also try downloading the FRC_MASTER_V14.BIN file from IFI. You should be able to find it there. Perhaps yours doesn't have any flash code within it.
I hope this helps....
Team MARS = 1.523 AU from the SUN!
Jim E.
Vista compatibility? EHaskins Programming 29 19-03-2007 11:22
File Compatibility DarkJedi613 Website Design/Showcase 4 16-02-2006 21:48
Compatibility of 2004 and 2005 Controllers Orborde Control System 7 21-01-2005 07:34
3dsmax r5/r6 compatibility? anishthakkar 3D Animation and Competition 2 05-01-2004 16:06
Pneumatics compatibility archiver 2000 4 23-06-2002 22:54
