Go to Post FIRST isn't for wimps. It never has been. - JaneYoung [more]
Unread 19-01-2008, 17:49
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Help--Program Light Stuck
Originally Posted by NinJA999 View Post
We were working on downloading code, and it got stuck in Program mode. We reset the robot, and the program light is still orange. Whatever we do (shut it off, reset it, reset from the oi, etc.), it will not go out of this mode. And it will not accept any programs. Help!
What base code are you using? What battery voltage does your OI indicate? Remove all power and let it sit for a minute or two and then try it again. In the extreme, you may need to reload the master code, which is available on IFI's website.
-Kevin
Kevin Watson
http://kevin.org
blinking program light tseres Control System 3 08-04-2007 17:45
!HELP! IM STUCK IN A SUBROUTINE!!! !HELP! cdennisxlx2 Programming 21 03-11-2006 17:15
RC stuck in "Program State" AndyB Technical Discussion 8 06-10-2006 14:17
help! Am really stuck!!!! pagemauck Programming 8 29-01-2004 12:38
