Originally Posted by Kevin Watson
What base code are you using?
We're using our code from last year (based on yours). I was uploading the code from yesterday (that had worked before).
What battery voltage does your OI indicate?
We had just replaced the battery. We replaced the battery again and it still didn't work.
Remove all power and let it sit for a minute or two and then try it again.
We removed the power for about 30 minutes and it still didn't work.
In the extreme, you may need to reload the master code, which is available on IFI's website.
Thanks, I am downloading now and will test it tomorrow.
