Go to Post Teamwork gracious professionalism robots = FIRST Robotics - Bcahn836 [more]
Unread 19-01-2008, 19:38
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Re: Plexiglass
Originally Posted by dtengineering View Post
Whether you use acrylic (Plexiglass) or polycarbonate (Lexan) I would suggest that when drilling holes in it that you re-grind your drill bits to make them "pointier" than a typical jobbers drill (about 60 degrees sounds right). Alternatively you can purchase specially ground drill bits for plastics. Yes, you can drill the plastics with a standard bit, but the pointier bits cut nicer and reduce the likelihood of cracking in plexiglass.
Jason
Question; Would not starting your hole with the smallest drill bit you have and working your way up to the hole size you want by redrilling with with the next size bit up also lessen the chance of cracking the Plexiglass ?
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Plexiglass Adhesives for electrical box Torboticsmember Electrical 17 22-01-2008 16:03
Plexiglass Help/Question Joe Matt Chit-Chat 11 06-07-2006 16:23
Plexiglass Archon Off-Season Events 6 25-04-2003 11:17
Can we use Plexiglass? Devil's Kid Technical Discussion 2 07-02-2002 21:49
Density of Plexiglass? turbidum Technical Discussion 14 24-01-2002 22:48
