Go to Post All battery terminals must be wrapped in tape or other insulating material AT ALL TIMES! - Al Skierkiewicz [more]
Unread 19-01-2008, 20:38
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Re: SRF04 Ultrasonic Rangefinder Unresponsive
tried it. It is now official that we are not gettting any feedback...
Unread 19-01-2008, 20:43
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
i have an SRF04 but also an SRF08, way better!!! and not to mention its controlled by i2c also it has a built in light sensor (CdS cell)
Unread 19-01-2008, 20:56
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I'm still not totally convinced. As Steve pointed out, the return pulse is very short, and it's possible that the pulse is coming and going faster than even the fast loop can keep up with. To be totally sure, could you set it up as an interrupt, and then see if you ever trigger it?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 19-01-2008, 21:31
geeknerd99's Avatar
Fire Hazard
AKA: Daniel Lin
It says that if there is no "echo," it won't timeout until 18 ms have passed. I'm sure the fast routine loops faster than 18 ms.
Unread 20-01-2008, 00:11
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
how about something like this. It should fire a ~20us drive pulse and then listen on the echo line. The echo line should be asserted shortly after the sonar is fired and remain high until the first echo is detected -or- no echo and the line will drop in 36ms.
void ping()
unsigned int count;
char usec;
#define drive_pin rc_dig_in01
#define echo_pin  rc_dig_in02
    //~20uS pulse out
    drive_pin = 1;
    for (usec=20; --usec != 0; )
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
    drive_pin = 0;
    //echo pulse should start shortly... timeout in ~20ms
    count = 35500;
    while(echo_pin == 0)
	count++;
	if (count == 0)
	    printf( "whoa, where'd the pulse go?\n");
	    return;
     // ok, count the pulse width, count*2 is approx. uSec.
    count = 0;
    while (echo_pin != 1)
	Nop(); Nop(); Nop(); Nop();
	count++;
            if (count == 0) break;
    printf( "count = %d\n", count );
    return;
Unread 20-01-2008, 11:42
Gdeaver Gdeaver is offline
FRC #1640
You could always fire up Easy C and check the operation with a Known working code.
Unread 20-01-2008, 11:52
the401tauntaun's Avatar
the401tauntaun the401tauntaun is offline
The Tauntaun
the401tauntaun is an unknown quantity at this point
Send a message via AIM to the401tauntaun
thanks a lot for your help! I will try this tuesday, when I can go back to the shop.
Unread 20-01-2008, 12:39
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Or you could try my single-pin ultrasonic driver.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Ultrasonic will not work with another Ultrasonic plz help Jackel148 Programming 10 10-05-2006 15:31
Programming Parallax Ultrasonic Rangefinder edman Programming 2 17-02-2006 08:35
Ultrasonic Sensor winners Programming 3 02-01-2006 20:55
Ultrasonic Rangefinder Operating On I2C Bus CapnBFG Electrical 10 04-06-2005 01:31
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
