Go to Post FIRST is supposed to be a learning experience. Learn first, win awards later. - evulish [more]
Unread 19-01-2008, 09:12
robotrobot2's Avatar
robotrobot2 robotrobot2 is offline
Computer Overlord
FRC #0151 (Tough Techs)
robotrobot2 is on a distinguished road
Building Practice Field
I know that on the FIRST website there is a set of instructions for building a practice playing field. However, the instructions aren't very complete and are hard to understand. Has any team built a playing field already or have suggestions about how to do so?
Everything can always be blamed on software:
The claw can't pick up the trackball-
programmers must have messed up the claw function.
The driver crashes the robot into a wall-
the drive code must not be responsive enough.
The robot repeatedly displays "HELLO WORLD"-
that probably is software.
Unread 19-01-2008, 12:19
Shelbo's Avatar
Shelbo Shelbo is offline
AKA: Shelby
FRC #0316 (LuNaTeCs)
Shelbo is a name known to allShelbo is a name known to allShelbo is a name known to allShelbo is a name known to allShelbo is a name known to allShelbo is a name known to all
Send a message via AIM to Shelbo
Re: Building Practice Field
You won't find everything you want to know all listed on one page as if you were sketching it out yourself. Spend a little bit of time with the blueprints and sketch it out on one paper so you have the dimensions in a shorthand that is easy for you to reference.
We're only building the overpass portion and marking the rest out on the floor. Using the blueprints for the team field drawing,
Overpass: pages 8, 9, and 11 tell you the lengths to cut the pvc to make the overpass sections. We modified it a little bit so that we used two more of #18 and did not use part #20 and #22.
Bases: pages 4 and 5 tell you the dimensions that the lumber needs to be cut for the base. We made two of these outside bases rather than following the prints for an inside base (because we were not making the lane dividers)
Ladder part of the overpass: we are only using part #23 found on page 12.
Don't glue anything until you have it all laid out.
Send me a private message if you need more details.
~Some people dream of worthy accomplishments while others stay awake and do them.~Anonymous(crunch weekend)
~SPACE PANTS!!!
(whats underneath???)
Unread 19-01-2008, 17:22
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
we just made one lane of the overpass for testing our robot on hurdling and such. We used only 1 1/4 PVC it sagged quite a bit, we glued it all and it works fine with a little bit of sag. We plan on running a 1" iron bar straight through the PVC the holds the balls.
Unread 19-01-2008, 20:34
Asiatique296's Avatar
Asiatique296 Asiatique296 is offline
AKA: caro
FRC #0296 (Northern Knights)
Asiatique296 will become famous soon enough
umm, team 296 really cheated on this. We bought 1 1/2 inch pvc pipes and only built 1/4 of the overpass. every thing else will be marked out by cones. boy, don't we loveeeee cones. Their so orange and bright and throwable !!!!
Although, won't do us much good after we busted our yoga ball.
Unread 19-01-2008, 20:54
Fab.Master's Avatar
Fab.Master Fab.Master is offline
FRC #0617 (Locomotives)
Fab.Master will become famous soon enough
I thought in Canada they were pylons not cones
Unread 19-01-2008, 22:00
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
We've built a full overpass and lane divider, sans the clear plastic in the lane divider. Feel free to PM me if you want pictures or have any specific questions.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 20-01-2008, 00:42
MasterRobot's Avatar
MasterRobot MasterRobot is offline
<= Psychedelic Cloud....
FRC #2438 ('Iobotics)
Team Role: Animator
MasterRobot will become famous soon enoughMasterRobot will become famous soon enough
ya we just went to home depot and bought some 1" and 1/2" PVC piping....
if you put some hard effort into it, you can kinda get an idea of the lengths you need. i hafta admit though, it was hard to get all the lengths right. The instructions weren't made for people building with PVC.
it isn't rocket science... but it can be confusing
Unread 20-01-2008, 12:05
Computer Overlord
So people are using a lot of PVC pipe to simulate the metal overpass?
Unread 20-01-2008, 14:22
fabalafae's Avatar
fabalafae fabalafae is offline
Guardian of the Grimmerie
FRC #0540 (TALON)
fabalafae is an unknown quantity at this point
In essence, yes. It's cheaper and easier to work with.
I am stricken and can't let you go
When the heart is cold, there's no hope, and we know
That I am crippled by all that you've done
Into the abyss will I run
Unread 21-01-2008, 14:00
StephLee's Avatar
AKA: Stephanie
We used iron inside PVC, I believe. Works pretty well, but if it gets hit with a ball the whole thing makes a pretty sweet approximation of a sine wave...
Unread 21-01-2008, 14:08
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
We recycled a bunch of steel pipe and Kee Klamp fittings from old practice fields to build our Overpass. FIRST used to love the stuff for field structures, so we've got several years' worth of it lying around in our building.
Jeff Waegelin
Unread 24-01-2008, 01:54
Team Role: Animator
a little update on PVC...
we used 1" PVC, and it isn't very strong...
it can barley keep up its own weight, the iron inside sounds good, but we don't have the money. Instead we're going to try putting some sort of rope/cord through the PVC to make it stronger, making it have a high tension to strengthen the PVC
Building the field Leo 1529 Technical Discussion 9 17-01-2006 16:20
Practice Field at NJ slickguy2007 Regional Competitions 1 06-03-2005 19:42
Practice Field at Palmetto? Kel D Regional Competitions 3 28-03-2004 23:47
Practice Field miketwalker Championship Event 3 29-03-2003 22:57
Building the Playing Field AJ Quick General Forum 15 13-01-2003 19:15
