Go to Post Mmmm scrap used parts. Dismantle, find data sheets and have fun.:D - techhelpbb [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 19-01-2008, 14:54
EROCK EROCK is offline
FRC #2450
EROCK is an unknown quantity at this point
Smile Gyros
Hey everyone when we received our kit of parts, it was missing the sensor strip (gear tooth, yaw rate gyro, dual axis accelerometer). We were wondering if anyone knew where we could obtain these boards.
-Eric of team 2450
Unread 19-01-2008, 15:08
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Gyros
If you were missing parts, you should've contacted FIRST by January 9 (10.1.1).
As for the actual parts, you'll have to settle for buying similar ones; the official sensors have never been available elsewhere.
Unread 19-01-2008, 16:03
FRC #2450
Re: Gyros
well what are people using the Gyros for? do we really need them? I have just found out that we had them but they were inadvertently broken. Is there any place where we could purchase a comparable gyros board?
Any input would be helpful...
Thanks
-Eric of team 2450
Unread 19-01-2008, 16:08
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Gyros
What are you planning on using the gyro for? Going to any major electronics provider you can get an Analog Devices evaluation board (the kit gyro is pretty similar to an ADXRS150EB).
We've always found the kit gyro a little turn-rate limited, so we've always used an ADXRS300EB, which can handle faster turn rates.
Unread 19-01-2008, 16:13
FRC #2450
Re: Gyros
We are also missing the gear tooth sensor and the dual axis accelerometer. Do you know where we could find these?
Unread 19-01-2008, 16:43
kaszeta's Avatar
Re: Gyros
I don't off the top of my head.
(I think we have unused ones from previous KOPs. I'll check our inventory, and if so I'll PM you).
Unread 19-01-2008, 17:07
FRC #2450
Re: Gyros
He thanks so much for the help. We really appreciate it. If you need any other info just message me.
-Eric of team 2450
Unread 19-01-2008, 20:08
kaszeta's Avatar
Re: Gyros
Haven't found it yet. I'll have the students look some more tomorrow.
Have you contacted FIRST yet? There's a good chance they'll send another sensor strip to you.
(Where in Minneapolis are you? I'm a former Minnesotan myself)
Unread 19-01-2008, 23:50
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Gyros
The gear tooth sensor is a basic hall effect sensor which can sense each tooth of a sprocket/gear in order to measure speed or distance traveled. You could get one of these from sparkfun.com, or you could use a different method of measuring wheel rotation, such as an encoder, which in my opinion are a little easier to use.
See Kevin Watson's page on encoders: http://www.kevin.org/frc/encoder/
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 21-01-2008, 18:20
FRC #2450
Re: Gyros
Our actual team is from St. Paul but I live by lake nokomis in Minneapolis, and I shall contact first to see if they will send us a new sensor strip.
Unread 21-01-2008, 18:58
kaszeta's Avatar
Re: Gyros
We have the GTS, but can't find a spare DAA or Gyro at the moment. PM me if you want me to send the GTS's.
Dual gyros Banjo Programming 1 17-02-2007 21:55
Gyros Ryan Cumings Programming 0 26-01-2004 16:22
Gyros!! RAWdealer59 Programming 1 12-02-2003 16:46
gyros archiver 2001 6 24-06-2002 02:35
Gyros archiver 2000 3 23-06-2002 22:58
