Go to Post When it all comes down to it, it's not gonna be the medal around your neck that makes the difference, but the memories that you think about when you look back on how you got there that makes the difference. - Beth Sweet [more]
Unread 19-01-2008, 23:07
Dick Linn's Avatar
no team (Synergy)
Re: Official Team 2526 Robot Model!!
Have you done any rough calculations of the forces required to raise such an arm with the weight and leverage involved? Especially with the limited air pressure and volume available... Can anyone help them out here?
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 19-01-2008, 23:20
RyanJK's Avatar
RyanJK RyanJK is offline
Does it come in chrome?
AKA: Ryan Kamphuis
FTC #3758 (Juarez Aztec Eagles)
RyanJK is on a distinguished road
We wanted to perform those calculations to see if our arm was feasible, but nobody quite knew how to do them, and we couldn't find a website that explained the process, so if anyone could tell us how to caculate those things, that would be great!
I'd also like to thank everyone who's helped us out, when we made this thread, we thought we would get some help, but the amount of help we got is surprising. Thanks so much!
Unread 19-01-2008, 23:21
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Thumbs up Re: Official Team 2526 Robot Model!!
Hey Maple Grove, this is Anoka, I was wondering what the dimensions of the circular pieces of the claw, and how they fit within the robot dimensions. It look's like a solid design. Good luck this year!
Unread 20-01-2008, 00:13
Dick Linn's Avatar
no team (Synergy)
Ryan, do a search on "class three lever". Just try to do the calculations on the middle elbow joint, ignoring the rest. It isn't too hard to "ball-park" it.
Better yet, borrow a bowling ball. Hold it straight down by your side, and have someone try to lift your arm and the ball by pressing up on the bottom side of your arm an inch or two below your elbow joint. That will give you an idea of the force necessary to raise that arm. You only have so much air pressure available. You can "super size" the cylinder, but you only have so much energy available in the compressed air tank and what the compressor can deliver on demand.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 20-01-2008, 00:29
run the trap!!!
Team Role: Human Player
I would be concerned with dropping the ball. I'm not sure that claw will be able to squeeze it tight enough. Some drawer-liner will definitely go a long way in providing "grip" to your manipulator.
I'd also be concerned with such skinny pieces of wood being broken. Our manipulator last year stuck out less than yours, and it got smashed several times . What we eventually did was wrap the wood with fiberglass; this made it very strong and it never broke again.
Just some tips to improve your design. Otherwise I think it is pretty slick! Good job CAD-ing your robot your rookie year! It took us 11 years before we did that!
-Philip J. Fry
Unread 20-01-2008, 00:50
Gertlex's Avatar
Gertlex Gertlex is offline
Alumni and mentor
AKA: E Relson
FRC #1015 (Pi Hi Samurai)
Gertlex is on a distinguished road
Figure out a way to brace the arm from swinging side to side too much. Turning with the ball lifted might well provide a heck of a lot of air drag causing significant problems.
A couple approaches...:
-Simple vertical rails on the side of the arms might help minimize swaying of the arm.
-Line the parts of each arm joint with aluminum plate (3/16 or 1/4, is my suggestion), and run a larger bolt size through that.
If you want help with the calculations, contact a local college with any sort of engineering at it... I'm sure you'd be able to get a professor to donate a couple hours of time doing/showing how to do the calculations to determine which cylinders you'll want.
Definitely make design changes so that you can get those arms in your starting box... You might need to be creative (but smart) with a method of having the claws start folded vertically, and then drop down and lock in place.
Unread 21-01-2008, 22:46
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
Originally Posted by Daniel Bathgate View Post
Make sure you understand how the pneumatic system works. As rookies last year, we designed an arm that bears a strong resemblance to yours, but didn't realize that the pneumatic cylinders can be either all the way out or all the way in, not stopped in the middle with the provided parts. We came up with a hack that used two solenoids per cylinder to achieve midpositions, but we had major control problems and ended up having to remove our arm. The cylinders you have also look undersized to me; I have doubts they will be able to hold the arm and trackball up.
That's a really cool design, just avoid making the mistakes we made with pneumatics.
Can you explain the hack further? We are looking at a way to get multipositions from a piston and this could be very helpfull.
thanks
Unread 21-01-2008, 23:47
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Are you sure those pistons will be able to pick up the ball?
Also, since you're using C-channel on the arm, be wary of any twisting that may occur during the match.
It's great that you guys realize the importance of modeling your robot with CAD software!
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 22-01-2008, 00:31
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
thanks
Take a look at this thread. I tried to explain what we did, and there is in my opinion a much better idea there as well.
Unread 22-01-2008, 01:01
mp.nighthawk's Avatar
mp.nighthawk mp.nighthawk is offline
FRC #1510
mp.nighthawk is an unknown quantity at this point
hey, i like your design, like evryone is saying about size and sharpness, sharpness can be controled by just makeing that graber more "safe" lol and then the size i thought id through in that i belive that it just has to fit that rule when it is all folded up and in its starting spot but once it is on the go and time is running then you can have it going crazy large like a transformer lol and also i would personaly look at your electrical bord setup, i belive what your doing is right, it just seams "off" to me
good luck building!
-Vic, 1510
it is a very sexy board!
i think i broke it,......
whats smoking?!
Unread 22-01-2008, 21:50
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
a couple of things that I would reccomend.
1. Make sure you are with your starting Dimentions (width, and Length)
2. Make sure you have more mass on the bottom, our team had to switch to a low rider so that our center of gravity would be lower...this Trackball is MASSIVE! it will cause your robot to tip.
3. The tips of your end effector look a little dangerous to the field elements.
over all, it is a fabulous design and congratulations for coming up with it so early in the season. good luck and don't hesitate to ask more questions.
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
Unread 22-01-2008, 22:01
edgar_amaro edgar_amaro is offline
FRC #2582 (Pantherbots)
Team Role: Student
edgar_amaro is on a distinguished road
hey !!! whats the height and how wide is your robot because before the match starts ... it has to fit within a 38 by 28 inch rectangle ..... doesnt it ???
but nice work !!!!!
Unread 22-01-2008, 22:51
DonRotolo's Avatar
Back to humble
FRC #0832
You'll be very disappointed with multiple positions using pneumatics. Also remember that gases compress, so if the load on the piston changes, it will move.
It can be done, however, with a double-solenoid valve (3-way), which is an off-the-shelf item. We used the gray solenoid valves, not the blue Bosch ones, and special-ordered them. No need to fool with two solenoid valves and fancy plumbing to modulate the exhaust port....
Don
Unread 22-01-2008, 22:56
esisso esisso is offline
AKA: Eitan
FRC #1242 (Team Smiley)
esisso will become famous soon enough
Send a message via AIM to esisso Send a message via MSN to esisso
the design looks great, similar to what we are building.....i dont quite see how yours folds up to fit within the 28x38x60...also as far as cylinders go, you'll need massive amounts of power, get the biggest bore possible for the bottom part of your arm...you might consider a design like this (excuse the poor designing and off scaling but i did it quickly in paint)
Name:	arm design paint.JPG
Unread 25-01-2008, 10:15
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Stick with the halos. Halos are your friend! Hence my new sig.
I'm curious as to how you plan to reinforce the halo claws so that a falling/bouncing ball doesn't destroy them. You could make them out of honeycomb aircraft aluminum and build in a break-point at the mount, with black rubber hoses to pad the sharp corners, but even that is fairly heavy. We're still prototyping different things for ours; we love the idea but we're becoming stumped on how to make one that's quality enough to last several competitions.
Still, glad to see a great idea wasn't only ours!
edit -- just noticed something else with your actuation --
It looks great in CAD, but I wonder how you mated up the pneumatic cylinders that are mounted to your 2 halo claws. They're sitting out there, freely able to move. In practice, this has created a problem with our prototypes: when the cyllinder goes out and opens your "claw", the claw is symmetric, and your top and bottom claws are lined up with each other perfectly. However, when the cyllinders go in and your claw closes, I seriously doubt your claws will still line up. The reason is that there is minutely more friction on one side of your claw than the other, and if there are no restrictions on how far inward one side of the claw can go the side with less friction will go past its symmetric position. I hope I'm making sense of this, I'll get a picture of our prototype later if I'm not.
2017 Scoring Model
CAD Library | GitHub
Official Robot Pic NeedMoreEngines General Forum 1 22-02-2007 10:47
New Model Posted - 2004 Robot Controller Ed Sparks Inventor 10 07-01-2006 23:12
[OCCRA]: Official Robot Size? Alex Golec OCCRA Q&A 1 07-10-2005 16:30
#d model of the robot base Damelvin 3D Animation and Competition 2 10-02-2005 18:50
Robot Height correction - Official Mike Martus OCCRA 0 17-09-2003 20:19
