Go to Post Go get Al, he probably isn't busy! - Jimmy Nichols [more]
Unread 19-01-2008, 15:56
Futbol.195 Futbol.195 is offline
AKA: Eric
FRC #0195 (Cyber Knights)
Team Role: Electrical
Futbol.195 is an unknown quantity at this point
Send a message via AIM to Futbol.195
fisher price
Does any one know if you could us 40 amp maxi fuses for the new fisher price?
GOOOOOOOOOOOOOOOOOOOAL!!!!!!!!!!!!!!!!!
2006
UTC Innovation And Control Award
Nationals Einstein Runner-Up
Unread 19-01-2008, 16:15
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
Re: fisher price
Use 20 or 30 amp breakers with the Fischer Prices.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 19-01-2008, 17:02
in between teams
AKA: Luke Van Oort
Re: fisher price
You could, but I wouldn't. Since a FP stalls at 60-70A (don't remember the specs for the new 9015 too well), a 40A breaker will only pop after it has been running at around 1/3 of free speed for a while; unfortunately, FPs don't like being run that slow for extended periods. We ran one on a 30A last year without issue, and will probably do the same this year (assuming we use the FPs this year). A 20A would probably work well too.
Team 1219: 2009 - Mentor
Unread 19-01-2008, 23:37
Re: fisher price
The Fisher Price motor is speced at 70 amps in stall. You can run whatever size breaker you want as long as it is sized for the wire you are using. If designed for running at well less than 30 amps then you can install a 30 amp circuit breaker if that meets with your design criteria.
A word of caution, however, the FP motor is very unhappy when running on the low RPM side of the curve. The internal fan is not very efficient at low RPM so the motor tends to over heat. This is normally not a problem if it weren't for the thermal breaker inside the motor. Once the motor temp is hot, the breaker trips and the motor stops for a period of time. Once the temp is elevated, each trip occurs at a lower current and there is a greater amount of time before reset.
Unread 20-01-2008, 01:08
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: fisher price
Just as a small word of caution... I had a VEX project that used the FP motor as the drive motor, and had a 20AMP circuit breaker on it, yet, the FP motor still burned up and gave a nasty rotten odor off. (It still ran, but it didn't sound good, and it smelled aweful). Now imagine it with a 40AMP... not a very good idea. If we had a choice, I would run it with a 5 or 10AMP breaker.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 20-01-2008, 01:29
Kat Kononov's Avatar
Kat Kononov Kat Kononov is offline
AKA: artqny
FRC #2022 (Team IDK)
Kat Kononov is an unknown quantity at this point
Send a message via AIM to Kat Kononov
Re: fisher price
What would happen if we run the FPs with a high load but for very short periods of time (one revolution or less)?
Unread 20-01-2008, 10:45
Re: fisher price
Kat,
It is hard to predict. If you are asking that the motor only runs for a turn or two at heavy load then the answer is likely no problem. It you are running at normal speed with intermittant heavy load, the answer is dependent on how often the heavy load is applied. The FP motor is a powerful motor for it's size but as with any motor, getting rid of heat is an issue. The FP designers made some tradeoffs such that the integral fan needs to spin at high RPM (the fan is attached to the motor shaft. You can see it if you look in the slots of the motor.). One little quirck about this motor is when it gets hot, the fan blades release from the shaft and stop moving altogether. If you look at the motor curves you can get an idea where the more efficient operating RPMs occur. Base you design on that type of decision. Don't hide the motor inside an enclosure and make sure the cooling slots remain open in your mounting design.
Unread 20-01-2008, 13:42
AKA: artqny
Re: fisher price
Ok thank you, Al.
Unread 20-01-2008, 16:47
Re: fisher price
Circuit breakers are not intended to protect motors. They are there to protect the wiring. You can burn up a Fisher Price motor at relatively low current if you run it at low speed under a moderate load for enough time. You can also run a Fisher Price motor at high current for a long time if it's spinning fast enough for its internal fan to be effective.
fisher price gears subzero15 Inventor 2 26-03-2007 15:29
Fisher Price Motors VerticalReality Motors 14 20-01-2007 03:31
Fisher Price Moters ThespisRules Motors 4 05-02-2005 23:38
Fisher Price Motors... archiver 2001 2 23-06-2002 22:36
fisher price motors archiver 2000 4 23-06-2002 22:36
