Go to Post It's not about going for any of the awards. Awards are to recognize what you are doing for First, your team, and the community. - SaraBailey [more]
Unread 20-01-2008, 00:53
Matth3w's Avatar
Matth3w Matth3w is offline
mh3w from yspilots :)
AKA: Matthew Winfield
FRC #2432 (Spartans)
Matth3w is on a distinguished road
Send a message via MSN to Matth3w
pic: Boeing and Hales HS early framework
Unread 20-01-2008, 00:57
RoboGeek99's Avatar
RoboGeek99 RoboGeek99 is offline
FRC #2582 (Panther Bots)
RoboGeek99 is just really niceRoboGeek99 is just really niceRoboGeek99 is just really niceRoboGeek99 is just really nice
Re: pic: Boeing and Hales HS early framework
Hey its amazing how much your robot is similar to ours. we were able to get ours rolling yesterday and fixed the kinks that it had today but the chassis design was almost identical except for basically one thing in which we made the electrical components in a two story box
Unread 20-01-2008, 01:54
CraigHickman
Posts: n/a
Uh. It's totally made of Kit components, so wouldn't it be very similar to every Kitbot out there? Just wondering....
Nice work! You folks are further than we are... Gearbox components should be rolling off the machines tomorrow, so we can couple them with the drive modules.
Unread 20-01-2008, 19:40
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Good work but i highly suggest that you grease those transmissions up or they will most likely seize up on you.
-Dustin Benedict
Unread 20-01-2008, 20:38
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
You might consider compacting your electronics layout to clear up space for your manipulator. Keep the good work up !
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 21-01-2008, 14:24
RoboGeek99's Avatar
Well all of the robots use parts from the same kit but even the chassis can be signficantly different because of all of the different ways to mount the gearboxes to the chassis or their alignment but still
Unread 21-01-2008, 15:23
Matt,
It is great to see you are almost on schedule. Rookies should have a driving base by now or be very close. I hope you checked your dimensions after you bolted it all together. The heads of the hardware will be included in your sizing. Some teams using this chassis, forget the hardware and find themselves 1/4" or more too big. Good luck and have fun!
paper: Low Latency Interrupt Framework dcbrown Extra Discussion 5 10-02-2008 15:56
Boeing 787 alphaone Chit-Chat 30 06-07-2007 23:08
Robot Framework lord Purity Pneumatics 3 21-01-2007 15:57
pic: Early Drivetrain Gabriel Mendez Robot Showcase 10 28-01-2006 00:50
Kickoff at CSUN or Boeing DougHogg Southern California Regional Robotics Forum 2 29-12-2002 18:29
