Go to Post Legend has it that Brandon installs the server in a bulletproof case shortly before Kickoff. That way, when the server explodes, the damage to surrounding things is minimal. ;) - Billfred [more]
Unread 20-01-2008, 11:26
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: A New Programmer
Originally Posted by Spartan151 View Post
I know I'll have to do some checking on the right motor, because for some reason it seems a little laggier than the left motor on our robot.
THat's usually the case. It happens (to us anyway) because the motor on the right wheel is turned around. The motors don't run the same speeds forwards an backwards, so when the left is running full fwd and the right full bwd, they're in the same direction, but the speeds are off slightly. It doesn't change a lot if ur moving slowly, since the system has a lot of friction, but when you gear up the speeds, the robot doesn't go anywhere near straight (speaking from personal experience in a narrow hallway)
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 20-01-2008, 16:58
The CIM motors don't have significant bias. They'll run the same speed in both directions. If you're reversing the motor direction for the other side of the robot by swapping the wires, the speeds should match well.
However, the Victor speed controllers do appear to have an asymmetric response around the defined neutral value of 127. If you're accounting for the need to reverse the motor direction in code, you'll probably notice this. When we tested things last year, true neutral seemed to be closer to 132.
Unread 20-01-2008, 20:10
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Looking at your code, I would recommend that you replace some of your absolute numbers with Calibration
values for future ease of Use. That way,you can change one Calibration value at the top of your program and it
changes all the values in your program saving you valuable editing time and the possibility of an editing bo-bo. For Example, if Fwd is > 127 for pwm outputs, try something Like Fwd_Low = 150 ; Fwd_Med = 170 ;Fwd_High = 190 , Similiarly, if
Rwd is < 127 how about Rev_Low = 104, Rev_Med = 84, and Rev_High = 64.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 20-01-2008, 22:03
Spartan151's Avatar
Spartan151 Spartan151 is offline
TCU Bound (Class of 2013)
AKA: Sean
FRC #2920
Spartan151 will become famous soon enough
Thanks for all the help guys. You've all been great. I'll be testing those things ASAP. Now, there are some other things I need help with, also. Our robot's claw is run by pneumatics. On our arm control, I need to program two buttons on the joystick (Or one to do both functions) to open and close the claw. How would I go about porgramming the buttons?
Unread 20-01-2008, 22:08
Spartan151's Avatar
AKA: Sean
FRC #2920
Could you explain exactly what you mean? I'm having difficulty understanding, partly because the computer I'm using now doesn't have MPLAB and partly because I only understand autonomous programming to a degree.
Unread 20-01-2008, 22:35
blaxbb blaxbb is offline
Ohio State Engineering Scholar
AKA: Brian Barrett
FRC #2331
blaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really nice
under ///*** DEFINE USER VARIABLES AND INITIALIZE THEM HERE ***/ or at the top of any .c file
to make it easier you should define your speeds so that you can update all of your speed values without changing every single one.
you can define your speeds once and call them multiple times
#define stop 127
#define forward 200
#define reverse 50
then instead of saying
pwm01 = 200;
pwm02 = 50;
you can say
pwm01 = forward;
pwm02 = reverse;
this makes it so much easier if you need to change a value quickly (at a competition)
"Whether you think you can or think you can’t, you’re right." - Henry Ford
www.vthsrobotics.org
Unread 21-01-2008, 10:06
Spartan151's Avatar
AKA: Sean
FRC #2920
Okay. It's beginning to make sense now. I'll give it a shot.
Unread 21-01-2008, 22:15
Spartan151's Avatar
AKA: Sean
FRC #2920
Okay. Once I get the basics done, I will need help programming the IR board functions, and programming the pneumatics for our claw to the arm joystick. I'll let you know when we get to that stage, but please, feel free to explain ahead of time. It'll help our team get a better understanding so there's no head-scratching later.
Unread 21-01-2008, 23:09
AKA: Brian Barrett
FRC #2331
Relays and IR Board
This is where the electronics and programming team/person has to work together.
The pneumatic cylinders are piped by solenoids (electronic valves,) which are controlled by a spike (relay.)
Relays don't use the analog 0-254 scale. They are essentially digital outputs that can be either forward, off, or reverse.
You map the relays the same way that you map speed controllers.
relay1_fwd = p1_sw_trig;
That would set relay1 to be forward every time your joystick 1 trigger is held.
IFI has a list of the joystick inputs here. pdf warning
As far as the IR, you need to read the digital input (1 or 0) and pass it through a conditional (if, else, switch) to execute a command.
if (rc_dig_in01 == 1) {
     pwm01 = pwm02 = 200;
else {
     pwm01 = pwm02 = 127;
change rc_dig_in01 to match up with the digital input that was wired to your bot
the reference docs to wire and train the IR board are here. pdf warning
Unread 22-01-2008, 19:30
Spartan151's Avatar
AKA: Sean
FRC #2920
Okay. Next question: Is it possible to program the joystick trigger to, when squeezed the first time, open the claw, and when pressed a second time, closes the claw?
Also, where do these code lines fit in at?
Unread 22-01-2008, 23:21
AKA: Brian Barrett
FRC #2331
I've been trying to figure that out too, can anyone else fill in.
I'm pretty sure you would have to write a toggle function, but I'm not exactly sure how it should work.
Unread 22-01-2008, 23:41
Examples of toggle functions are common on the Chief Delphi forums. Here's another:
  static char prev_trig = 0;
  static char toggle = 0;
  if (p1_trig && !prev_trig)
    toggle = !toggle;
  prev_trig = p1_trig;
This will switch toggle from 0 to 1, or vice versa, each time the port 1 joystick trigger is depressed. You can test its value to decide what to do next.
Unread 23-01-2008, 09:12
Spartan151's Avatar
AKA: Sean
FRC #2920
    toggle = !toggle;
Okay. Taking this code, where do I write in the relay values, if they need to be written in? Or is that done with the previous code for the relay values?
Unread 23-01-2008, 00:06
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Hi,
You can try this, but I don't make any guarantee.
Toggle_gripper(current state)
int temp_state;
If ((p3_sw_trig==TRUE)&&( current _state== CLOSED)
temp_state=current_state;
else if (p3_sw_trig==TRUE)
temp_state=OPEN;
else if ((p3_sw_trig==FALSE)&&(current_state==OPEN))
temp_state=CLOSED;
} return (temp_state);
In you Default _Routine, simply call the function:
pwm_state=Toggle_Gripper(current_pwm);
if (current_pwm<>pwm_state)
pwm=pwm_state;
I'm writing this off the cuff, you will need to correct the syntax and apply your own values for the pwm assignments, but it looks plausable. Good luck.
Team MARS = 1.523 AU from the SUN!
Jim E.
NEW PROGRAMMER!!!!! NEED HELP!!!! delphi demon Programming 5 19-04-2007 13:22
pic: Team 1249's new programmer roborat Extra Discussion 4 23-06-2006 22:02
Senior Programmer: advice on training new recruits Jeff_Rice Programming 9 04-01-2005 16:59
Help for New Programmer Mike375 Programming 3 27-09-2001 09:04
