Go to Post The bulk of the hardest fun you'll ever have is opening up that box in early january, and the six week of chaos that that box of parts puts you through. - Joe G. [more]
Unread 20-01-2008, 12:42
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: Overpass rigidity?
I wasn't at the Manchester kickoff, nor have we built an overpass to the official specs, so I can't make a direct comment on the field. However, the real field is aluminum pipe, not steel as called out in the "simplified" drawings. I think the welded joints on the aluminum field should be a bit stronger (and stiffer) than the NPT connections on the steel pipes. The extra stiffness of the connections should carry over to a stiffer overpass in general. However, the long span of the overpass is still a long span, and the aluminum (as you know) is 1/3rd the stiffness of steel. So, I can only imagine that, yes, it'll probably be as bouncy as you're presently experiencing.
We've already taken some good shots on the overpass with our robot, and the ball certainly makes the thing shake like jello. We've also knocked our overpass over. I don't recommend doing that, ever.
Bengineer
Hurdling using the overpass robogeek753 Rules/Strategy 40 20-01-2008 17:02
removing trackball from overpass Tyler Grooms Rules/Strategy 4 15-01-2008 12:39
under overpass Bohalin General Forum 4 14-01-2008 11:47
rule question on scoring above overpass Robo_Coyote Rules/Strategy 35 08-01-2008 09:03
Height of overpass Evert General Forum 8 07-01-2008 14:11
