Go to Post The only thing happy about ship day is the promise of sleep coming soon... - StephLee [more]
Unread 19-01-2008, 13:00
cstringer cstringer is offline
None #2339
cstringer is an unknown quantity at this point
MPLAB PROGRAMMING PLEASE HELP!!!
I have no idea what I am doing and would be eternally greatful if anyone could help me.
Unread 19-01-2008, 13:27
epl692's Avatar
epl692 epl692 is offline
all roads lead to citys.
AKA: Eric L
FRC #0107 (R.O.B.O.T.I.C.S.)
epl692 is an unknown quantity at this point
Send a message via MSN to epl692
Re: MPLAB PROGRAMMING PLEASE HELP!!!
We all might love to help you, but you have to explain the problem more then just HELP!!!
- Eric Lynema, Team 107 Programer
Unread 20-01-2008, 01:27
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
OK TRY THIS..
1) Install MPLAB IDE from the disc
Select “no” to any of the view driver…” questions.
“Yes” to restart the computer.
2) Install MPLAB C18 Compiler.
Use the default directory, you’ll go through “select installation directory”, “select components”, then,
in “select configuration options”… SELECT ALL 6 OPTIONS
3) Install Innovation First Loader (NOTE: When “IFI loader setup” comes up you have to click the funny picture to continue…)
4) download FRC CODE from
http://www.ifirobotics.com/rc.shtml#Programming
5) unzip all the files to a known directory close to C:... Like C:\FR_Code (just for example.)( There's a reason for this... there's a limit on the number of characters in a file name so the closer to C:\ the better)
6) Start MPLAB. At the top, select “File”, “Open Work Space” and then browse to C:\Frc_Code (Or where ever you downloaded in Step 4) ( It may be under directory Frc_Code_2007_8722) but find FrcCode.mcw
7) This will bring up a workspace with all the necessary files.
8) you can open any file and modify it if you want but just for test purposes, first:
9) select At the top… “Project” and then “Build All”
10) You should get a lot of messages without any errors.
11) Start IFI Loader.
12) Browse to C:\FRC_ Code \FrcCode_2007_8722\FrcCode.hex
13) Connect the programming cable to the programming port on the RC Controller
14) Select download
All this reloads the default program back into the RC unit.
To modify the code… start at step 6, modify the code and continue with the rest of the steps.
Unread 20-01-2008, 10:32
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
the default code should give you most of what you need
It will let you drive the robot if you set up the electrical the same way.
If you have a specific question I would be happy to help
ALWAYS a mechanical problem!
Unread 20-01-2008, 12:29
p_a_3 p_a_3 is offline
FRC #1648
p_a_3 is an unknown quantity at this point
When I ried compiling the default code I got two errors:
Error - Coff file format for 'ifi_library.o' is out of date.
Error - Could not build member 'ifi_library.o' in library file 'C:\Robots\2008 First programming\FrcCode_2007_8722\FRC_library_8722.lib '.
Errors : 2
Where can I find the current ifi code or library?
Thanks
Unread 20-01-2008, 13:11
Errors : 2
Thanks
What version of MPLAB are you using? you can only use Version 7.20 so you have to load it from the disc you get in the kit. If you downloaded MPLAB 8.0, you'll have to remove it from the computer and re-install 7.2
Steve
Unread 20-01-2008, 13:49
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Originally Posted by cstringer View Post
I have no idea what I am doing...
I'm with Stringer here. I'll try using the ROBOTC programs in MPLAB(and the programs are perfect!) and the program receives 45 errors. What's wrong with it? (Is this what you're having problems with Stringer?)
The system is down.
Rockford Robotics 2039: Think outside the bots.
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
MPLAB 7.20 Help please? groovy69 Programming 14 22-01-2007 02:00
Please help; HUGE mplab problem brennerator Programming 5 09-01-2007 01:25
MPLAB Help, programming and compiling RedOctober Programming 2 23-12-2005 17:46
PLEASE HELP US FIND OUR MOMMY (or MPLAB) superlou Programming 3 23-02-2004 16:33
