Go to Post Someone want to channel their inner Mark Leon and do the math? - Billfred [more]
Unread 20-01-2008, 12:15
flightofone flightofone is offline
AKA: John Clayton
FRC #2104 (Colonel Robotics)
flightofone is just really niceflightofone is just really niceflightofone is just really niceflightofone is just really niceflightofone is just really nice
Send a message via AIM to flightofone
Robocoach fashion accessories
Here is what our team robocoach will be wearing at the Hartford Regional. The NVG headmount allows our high-powered IR transmitter to be naturally aimed at the robot's IR antenna, with only a low likelihood of getting off-target and frying opponents IR receivers. All while leaving the hands free for the XBOX360 controller used to signal the robot in the first 15 seconds, and play NASCAR for the remaining 2 minutes.
There's a fine line between fishing and just standing on the shore like an idiot. - Stephen Wright
________________________________________
2007 UTC Regional - Finalists (thanks 25 & 176)
Unread 20-01-2008, 12:45
CzarValvador's Avatar
CzarValvador CzarValvador is offline
AKA: Val
FRC #1717 (D'penguineers)
Team Role: Electrical
CzarValvador has a spectacular aura aboutCzarValvador has a spectacular aura about
Re: Robocoach fashion accessories
Um, isn't the Xbox 360 Controller on RadioWave Frequencies? Thats way off the charts on whats allowed and whats not, is it not?
Unread 20-01-2008, 12:47
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
The shirt cooler than the headgear... I can see alot of people bumping into things this season.
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
AKA: John Clayton
I should have mentioned we use the wired version of the xbox controller. It is plugged into a USB port of a tiny laptop hung around the neck of the robocoach, which reads the button inputs and sends them to the IR transmitter.
Unread 20-01-2008, 12:49
cobrawanabe1699's Avatar
cobrawanabe1699 cobrawanabe1699 is offline
That kid with the TIG welder
AKA: Matt, or to those in the northeast, THE BOBCAT!!!
FRC #1699 (ROBOCATS)
cobrawanabe1699 is a jewel in the roughcobrawanabe1699 is a jewel in the roughcobrawanabe1699 is a jewel in the rough
Unfortunately, I am going to HFord, but not with my team. Therefore, the Bobcat will not be there this year. I'll look for him tho, and try to get a sig.
BOBCAT OWNS
I done welded me a robot!
TECHNICAL JUDGE:
FLL Bash @ The Beach 2007 Regional Competition
FLL State Championship, CCSU 2007
FLL Bash @ The Beach 2008 Regional Competition
ATTENDING IN 2009:
FIRST Kickoff in NH
FIRST Regional Competition: Washington DC
FIRST World Championships: Atlanta, Georgia
"If it ain't broke, fix it 'till it is."
Unread 20-01-2008, 12:50
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Wait a second... are you encoding data from the XBOX controller over the infrared and transmitting it to the robot? (aka IRDA)
We wanted to do this too... but the game manual says that you can't encode data into the infrared in any fashion. You must have four distinct functions each assigned a unique IR code.
<G49>
ROBOCOACH Signaling – If the ROBOCOACH will be providing signals to the ROBOT,
then prior to the start of each MATCH the ROBOCOACH must place a Signaling Card in the
ROBOCOACH STATION. The Signaling Card shall be a 3-inch by 5-inch card listing the
one to four actions that can be commanded by the ROBOCOACH.
<R65> (excerpts)
SIGNALING DEVICES shall be designed to communicate signals from the ROBOCOACH
to the ROBOT. SIGNALING DEVICES are excluded from Rule <R64>. SIGNALING
DEVICES shall:
>not use changes in the signal states to encode or transmit larger messages (e.g. Morse code)
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 20-01-2008, 13:12
AKA: John Clayton
Yes, we are sending four ASCII codes, one for each button press (or Left/Right toggle):
'A' - turn left 10-degrees
'B' - turn right 10-degrees
'C' - speed up 2-fps
'D' - slow down 2-fps
That should meet the spirit and letter of the rules.
We are using a different carrier frequency than IRDA to minimize interference.
Unread 20-01-2008, 14:43
AKA: Alex
In that case... Cool! When you said XBOX controller I thought you were sending a few bytes of data (such as X and Y axis position on the joysticks) over some kind of serial interface.
Guess it's an odd conclusion to jump to... but its just me being unhappy to find out you couldnt do anything too crazy with the infrared. When we first herd about the IR our team wanted to make an IR joystick... then we read the rules.
Sorry!
-q
Robocoach signals loophole? jacobhurwitz Rules/Strategy 51 29-01-2008 09:16
<G49> ROBOCOACH Signaling t3hroxor Rules/Strategy 3 09-01-2008 20:41
Organize EasyC functions in a fashion we like? Chris_Elston Programming 3 20-02-2006 18:53
pic: New spring fashion? Alex Pelan Extra Discussion 25 04-06-2005 18:50
Duct tape.... the fashion archiver 2001 5 24-06-2002 04:22
