Go to Post Earlier today, I finally saw a copy of the [WFA] essay that was submitted by my team (there will be a separate reckoning later with all those that kept this a secret from me). The narrative overwhelmed me. - dlavery [more]
Unread 16-01-2008, 18:47
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
backup battery charger
Hello all,
Does anyone know where you connect the 12 input for the backup battery charger that FIRST put out the schematics for? If you connect to the breaker panel the battery tries to run the robot electronics. Do we connect it on the battery side? Help!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 16-01-2008, 18:53
AKA: Ledge
Re: backup battery charger
Help!
Unread 16-01-2008, 19:54
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
I would guess it goes on the breaker side, because FIRST would want everything off when the breaker is off.
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 16-01-2008, 20:16
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
The 12 V input to the charger circuit should be attached to a small (20A) breaker from one of the breaker panels. (According to my reading of the wiring rules.)
The output of the circuit goes to both the RC backup input and the backup battery. When you connect this, you'll probably splice into the backup battery connector cable, or attach the backup battery connector cable to the charger board, then the charger board to the RC.
-JEE
Unread 16-01-2008, 22:39
AKA: Ledge
When I connect it like you said, the backup battery tries to light up the motor speed controllers and spikes. This would drain the battery when you turn the robot off. Has anyone out there actually done this that could help us?
Unread 16-01-2008, 23:47
The IFI-provided circuit has the small issue of powering the entire robot from the backup battery. A simple addition will fix it: just put another 1N5820TR diode in series with the power input. That will prevent the circuit from back-feeding the breaker panel.
Unread 17-01-2008, 01:06
FRC #6357
Hmm...Al's on the money. It makes perfect sense both that the charger would try to power the robot, and that the diode will fix it.
I was basing my comments on the schmatic. My team has never used on board charging before. We'll be sure to include this modification.
-JEE
Unread 17-01-2008, 07:16
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Yep. We built the circuit last year, and then chucked it out. You're much better off going to a hobby store and spending $25 on a high capacity 7.2 volt pack for RC cars and a nice charger actually comes with it. Once we did so, we never once had a backup battery issue, even when running with the same battery all day (with camera).
Unread 17-01-2008, 10:53
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
We also put a diode on the 12V power into the backup charger to prevent the backup battery from trying to power the electronics. Did that last year and plan to do it again.
Brian K
Team 1225 Robotics Mentor
Unread 17-01-2008, 18:28
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
It would seem that FIRST should modify the official schematic... where do we send the suggestion?
Unread 20-01-2008, 13:11
d235j d235j is offline
FRC #4454
d235j has a spectacular aura aboutd235j has a spectacular aura about
A suggestion should be sent to Innovation First (as they provided the original schematic).
Unread 20-01-2008, 13:21
organman42's Avatar
organman42 organman42 is offline
AKA: Jeff
FRC #1073 (The Force Team)
organman42 is an unknown quantity at this point
I heard that there was a new circuit for this year's backup battery charger. Is this true? If so, where can I get the schematic? (I have the one from last year already) Thanks
"I have a different vision of leadership. A leadership is someone who brings people together."
Unread 20-01-2008, 13:24
RyanN's Avatar
RyanN RyanN is online now
RyanN
AKA: Ryan Nazaretian
If, and when, a new circuit is posted, it will end up here: http://ifirobotics.com/rc.shtml
Please read the thread before you post, because you should have noticed that there has not been an update to the circuit yet...
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 22-01-2008, 00:44
eeeeweeezeee's Avatar
eeeeweeezeee eeeeweeezeee is offline
menace to public safety
FRC #0114
eeeeweeezeee will become famous soon enough
Send a message via AIM to eeeeweeezeee
yep, the circut is more than a little flawed. using about 1/3 of the parts in the schematic, I made a small variable power supply today that I am a lot more happy with. now, i just charge that battery however I want (within the margins of ni-cad common sense) and I can also use the simple circuit to power various other devices from any DC source between the desired end voltage and 30 something volts. to make the LM317T into a variable power supply you add a 240ohm resistor in between the Vout and ground pins and then connect the ground side of that to a 5k potentiometer if I remember right. look up "lm317t" in Google and you will see lots of simple power supplies like this.
EEEEWEEEZEEE
was here
Unread 22-01-2008, 08:11
Please note my emphasis in the following rule...
<R49> The 7.2v backup battery may be charged on or off the ROBOT. When off the ROBOT, the battery is to be charged with a 7.2V backup battery charger. When mounted on the ROBOT, the backup battery may be charged from the 12VDC primary battery by using the custom charging circuit available from Innovation First Inc. or any similar charging circuit (note: IFI will provide the design for this circuit on the IFI website, however teams must obtain the parts for this circuit and assemble it themselves). The use of this circuit is strongly encouraged.
NiCad battery technology requires some method of limiting charge current to prevent battery failure. Don't fall into the trap that you need to charge the battery on the robot from the main battery. A few extra battery packs and the IFI wall charger will get you through any competition.
Where to connect the backup battery charger Never_Fade Electrical 6 16-01-2008 23:54
Alternate Backup Battery Charger Phalanx Electrical 5 24-02-2007 14:51
(Earlier version of) Backup onboard charger not correct Ralph Nicovich Electrical 49 08-02-2007 07:46
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
battery charger archiver 2001 3 23-06-2002 23:20
