Team 1662 Takes off
so our team started assembling our robot yesterday, this is what it looks like:
Yesterday (Day 11 of the season) ![]() Today ![]() |
Re: Team 1662 Takes off
neato! you took out the second stage gears too?
Wide wheels again! But they keep keep shrinking in diameter every year...
Looks good, can't wait to see what you guys put on top of it. |
Make sure you can fit a secure battery in there somewhere!
I guess you guys drilled and tapped gearbox mounts yourself into the extrusion piece? We did the same thing.
Those lexan plates on the Toughboxes are very easily cracked.
I would bump them up to be aluminum especially with a 2 motor setup. I'm not saying you have to, but check those plates often, especially with the torque you are going to be putting on that system. Only time will tell whether or not the lexan "fails" in that system, but we're not taking any chances and remaking them in aluminum. |
#7
One of my students accidently cracked the LEXAN when he was installing a motor, he had the bearing backwards (Flange facing out) and it caused the motor to be crooked as he tightened it on and the crack started at the mounting hole. Any one using the Toughbox needs to be checking those plates reguarly. |
#8
| pic: 1662 | M4 Sherman | Extra Discussion | 2 | 07-04-2006 01:04 |
| WPI Team 190 Takes Off | WernerNYK | Robot Showcase | 3 | 21-02-2003 15:24 |
| Image Discuss: Team 624 takes a coffee break?!?! | CD47-Bot | Robot Showcase | 4 | 21-02-2003 09:42 |
| Team 93 Takes..... | Tyler Olds | Thanks and/or Congrats | 5 | 30-04-2002 18:48 |
| Team 93 Takes..... | Tyler Olds | Championship Event | 0 | 27-04-2002 17:25 |
