Go to Post But please, don't attempt to subvert the rules. It almost invariably becomes more trouble than it's worth. - Billfred [more]
Unread 20-01-2008, 11:55
bubbablahmon bubbablahmon is offline
FRC #0617
bubbablahmon is an unknown quantity at this point
pic: we decided to leave our electronics box as the cardboard box FIRST gave us, it was prelabeled.
Unread 20-01-2008, 11:58
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: pic: we decided to leave our electronics box as the cardboard box FIRST gave us,
you know, I think most teams don't even consider the possiblity of using cardboard as an electronics mounting board. It's extremely lightweight and fairly rigid (well rigid enough if you arent using it for bracing and such). You can even use multiple sheets to make it more rigid. also, it is really easy to cut and all you need is an xacto knive. Thoughts?
thanks, Vivek
EDIT: good job on wearing safety glasses.
"we don't build robots, we build people"
Unread 20-01-2008, 12:12
in between teams
AKA: Luke Van Oort
I've thought about using cardboard, but I have never actually tried. The stuff can be pretty strong, but once it gets damaged it weakens significantly and fails more... I guess I'm just not brave enough to try it. I wish you luck with it! BTW, those are some sexy treads!
Team 1219: 2009 - Mentor
Unread 20-01-2008, 12:50
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
I hope something goes over it or you put standoffs inside the box so your electronics don't get crushed when a 40" ball falls on it. I think once you get past that you'll have a great, light weight, and semi-robust controls system. Good luck!
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 20-01-2008, 13:41
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
that is some beautiful Tank drive there guys. nice idea using he cardboard box, makes it all very lightweight and organized (or at least contained ). make sure to put the box somewhere where it wont get damaged or else!
Unread 20-01-2008, 13:45
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
lol nice, we normally use lexan.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 20-01-2008, 14:05
Make sure you can see the lights when the box is closed. That is an inspection issue, and is so that the IFI reps can see what is going wrong if your robot dies.
<R72> The Robot Controller must be positioned within the ROBOT so that its indicator lights can be seen during inspection and when standing three feet in front of the ROBOT while the ROBOT is in the STARTING CONFIGURATION at the beginning of a MATCH. This will greatly facilitate analysis in case of problems.
Unread 20-01-2008, 14:29
Fab.Master's Avatar
Fab.Master Fab.Master is offline
FRC #0617 (Locomotives)
Fab.Master will become famous soon enough
we're gonna cut the top off and put saran wrap on top. thanks for the compliments on the tracks. I designed them in AutoCad and we sent the file to a company called Old Dominion Brush who has CNC waterjet and they cut them out for $65 a piece (4 pieces total). We then used 1"x1" 8020 through the inside rails at the back, tapped the end 1/4-20 and use flat head bolts to pull the sides tight. the middle is the same thing except with a 1"x2" piece. our floor pan is alumalite panel from 8020 and is bolted to the 8020 cross members. But the best part is that with electronics we this whole assembly weighs roughly 35lbs. I'll try to get more pics on monday or tuesday with closeups.
Unread 20-01-2008, 16:39
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Out of curiosity, why did you decide to use treads this year? This seems to be about the worst year ever, with the exception of 05, maybe, to use treads.
2001-2004: Team 100
2006-Present: Team 254
Unread 20-01-2008, 16:49
That guy
AKA: Dennis
imo tracks was a bad way to go in 05, it was very compact and you needed to be able to turn well. But i was wondering also, it's going to make turning hard.
Unread 20-01-2008, 17:01
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I'd recommend against that, as it's likely to either keep the victors from breathing or get caught in a fan (which could provoke a release of magic smoke). Ventilation is a good thing, as are rigidity and cable management.
Make sure the button on the master breaker is easily accessible from outside the robot. This is also an inspection and safety issue.
You're making some interesting design choices. I hope they work out well for you.
Unread 20-01-2008, 19:48
Fab.Master's Avatar
we decided to keep the tracks since this was our first drive system that worked consistently all of the time. We also like the compactness of this design with the motors parallel to the tracks as this opens up more space than conventional designs. we know its not the ideal thing but that's why we have programmers (to make it all work like we want it). I just build and drive
Unread 20-01-2008, 21:51
sethw sethw is offline
FRC #0639
sethw is an unknown quantity at this point
Tracks really work rather well - our team has used them several years and never had a problem with them. Turning with them is easy enough. We even won regionals with track-driven robots in both 2004 and 2005. They're a very viable option.
-Seth
Unread 20-01-2008, 21:55
That guy
AKA: Dennis
Really? we never have had a lot of luck with them, from what i hear from old members.
Unread 20-01-2008, 22:20
in between teams
AKA: Luke Van Oort
From what I understand, a good track system needs a lot of thought and planning (especially in the tensioning system). With careful planning they can be equally maneuverable, be better at handling obstacles, and possess a lower CoG than wheels; with bad or sloppy design they can be quite expensive (belt replacements), unreliable, have difficulty turning, and be very heavy. Most of the good track designs, like 180's and 48's, have gone through many, many iterations to reach their current level of effectiveness.
pic: Team 1930's Electronics Box Hiteak Extra Discussion 13 01-02-2007 07:31
pic: Tin Cans 2158 Electronics Box 2007 lynca Extra Discussion 15 20-01-2007 02:03
pic: 114's electronics box CraigHickman Extra Discussion 0 15-02-2006 09:35
pic: Our Gear Box Victor_Mec Extra Discussion 1 11-03-2005 09:35
What was in the 5th box that the rookie teams got? Jack21 General Forum 3 12-01-2004 03:55
